• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Leander.van.Gorsel
    Known error in flat pattern - 2D Sketch Punch Representation
    561 Views, 8 Replies
    10-03-2011 03:01 AM
    I've a problem in Inv 2011 SP2 and 2012 SP1 with 2D Sketch Punch Representation.
    See attached file for the explanation of the problem or this Link to animated problem.
    I've contacted Autodesk about it, and it is a known problem, but perhaps anybody know a sollution for it?
    Kind regards,
    Leander van Gorsel
    Green check.png  Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful
    Software: Inventor Series 2013 SP1.1 x64
    OS: Windows 7 Professional x64
    CPU: i7-975X // RAM: 12Gb
    VGA: GeForce GTX 280M
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: Known error in flat pattern - 2D Sketch Punch Representation
    10-04-2011 09:34 PM in reply to: Leander.van.Gorsel
    I can confirm that there is an issue in Inventor. Meanwhile can you provide me the dataset for further testing. Will try to see whether we could get you a workaround on this.
    Will get back to you soon.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Autodesk, Inc.
    Active Contributor
    Leander.van.Gorsel
    10-09-2011 11:41 PM in reply to: VinodBalasubramanian
    Hi Vinod,
    Thank you for the reply. I can provide you the dataset, but can I send it to an email address?
    Leander van Gorsel
    Product Support
    02-06-2012 04:26 PM in reply to: Leander.van.Gorsel
    This issue has been escalated to Autodesk. Autodesk Support team is currently working with the customer and will keep you all posted as soon as we have some additional information to share.
    Autodesk Support
    Autodesk, Inc.
    Valued Mentor
    jcneal
    08-27-2012 09:46 AM in reply to: VinodBalasubramanian
    is there any fix on this issue?
    thanks.
    Active Contributor
    Leander.van.Gorsel
    08-28-2012 01:11 AM in reply to: jcneal
    Hi JcNeal,
    Unfortunatly not. I've reported this problem on the SP1 Beta site, perhaps after 1,5 year sombody will look at it and solve the problem.
    Did you have the same problem with the sheet metal?
    Leander.
    Valued Mentor
    jcneal
    08-28-2012 05:39 AM in reply to: Leander.van.Gorsel
    yes, it is on sheet metal.
    I got reply from another post thru. please check it out
    http://forums.autodesk.com/t5/Autodesk-Inventor/Punch-features-sketch-in-derived-part/td-p/2556587
    *Pro
    jletcher
    08-28-2012 06:24 AM in reply to: Leander.van.Gorsel
    To me it is an issue because lack of checking... This has been known the day they installed simplified sketches to the punch. I reported this way back then and never ever got it fixed.
    The best I remember this is what I was told.
    When making punch features with simplified sketch all is good but when you derive the part it no longer knows this information it is lost in the derived translation.
    A fast work around make 2 parts the same no derive and split for left in one split for right in the other.
    And here we are many releases later still an issue..
    And you all  want to know why I get upset about a new interface. Well they had time to make an interface but not fix a bug.......
    Good luck maybe this time they will fix it................ In release 2020
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Active Contributor
    Leander.van.Gorsel
    12-19-2012 05:04 PM in reply to: jletcher
    Hi James,
    Thanks for your reply!
    Just two remarks:
    1st: The workaround you described won't do it for me, because the product in which these parts are used in will be changed with a VBA program / Add-in (It's just a kind of ETO but better ;-) So I want to change the basepart and by doing that the depend parts will follow.
    2nd: The problem isn't in using the deriving feature, but it is a bit deeper in Inv. The problem is the flipping of the normal of a plane on which the simplified sketch is drawn at. This problem of flipping planes occurs also in other parts of Inv. I've reported this in several ways, but it seems to be a bit to hard to fix...?
    Regards, Leander.
