• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Knockout representation
    129 Views, 6 Replies
    08-18-2008 08:07 AM
    Any good ideas on how to show a good representation (quick and easy) of a knockout on a thin steel part?
    Please use plain text.
    Re: Knockout representation
    08-18-2008 10:04 AM in reply to: jbscott2121
    :smileyhappy:
    *Gary R Smith \(Autodesk\)
    08-18-2008 10:20 AM in reply to: jbscott2121
    How frequently is this an issue for you?
    What sorts of knock-outs do you typically encounter?
    1. Model the knock-out.
    2. Include a center mark in the sketch.
    3. Include an alternative sketch if the knock-out is complicated.
    4. Create a Punch iFeature
    5. Convert to a table-driven family of iFeatures (if you'll use a lot and
    knock-out lends itself to being parameter driven)
    With the Punch saved, you can now use in your folded models and subsequently
    decide if you want to see:
    a) the punch
    b) the center point only or
    c) the alternative sketch
    in your flat pattern.
    Gary R. Smith
    Autodesk Manufacturing Solutions Division
    Technical Publications - Subject Matter Expert
    Portland, OR
    2.33GHz 2GB IBM ThinkPad T60p; XP pro SP2
    ATI Mobility FireGL V5250 driver: 8.293.1.0
    08-18-2008 10:24 AM in reply to: jbscott2121
    Thanx Gary
    08-18-2008 11:34 AM in reply to: jbscott2121
    In the attached ZIP file, I have placed a simple R2009 sheet metal part onto
    which I have placed several instances of the included iFeature. The iFeature
    contains a table with three size variations. The iFeature places a hole in
    the sheet, uses the same sketch to create the "still attached" blank (which
    has had a radius applied to the back).
    On placement, I used a single sketch to define the placement centers.
    I deselected the centers that I didn't want on the first placement (then
    shared the sketch).
    I then reapplied using different diameters.
    You can make your version as complicated as you want.
    The flat pattern was then set such that the punch was shown using the center
    marks only.
    If you had a really complicated punch, you could create an alternative
    sketch to represent the simplification that you wanted to show on your flat
    pattern and include it with your sheet metal punch iFeature.
    *Dennis Jeffrey
    08-19-2008 01:28 AM in reply to: jbscott2121
    Here's another punch fromthe Electrical Box in Inventor\Samples\Models
    Dennis Jeffrey, Autodesk Inventor Certified Expert
    Autodesk Manufacturing Implementation Certified Expert.
    Instructor/Author/Sr. App Engr.
    AIP 2008 SP2, AIP 2009 PcCillin AV
    HP zv5000 AMD64 2GB
    Geforce Go 440, Driver: .8185
    XP Pro SP2, Windows XP Silver Theme
    http://teknigroup.com
    wrote in message news:6009150@discussion.autodesk.com...
    Thanx Gary
    Valued Mentor
    jcneal
    04-18-2012 07:43 AM in reply to: *Gary R Smith \(Autodesk\)
    is there any way to put double knockout and single knockout in one punch tool?
    now, i make two punch tools. one for single and one for double.
    thanks a lot
    spec: window 7 & inventor 2012
