Autodesk Inventor
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Issue With Imported AutoCAD Block disappeari ng.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
111 Views, 1 Replies
11-21-2012 08:21 AM
I have recently ran in to an issue where the imported AutoCAD blocks disappear when I export to .dwf, this only appears to happen after I add the revision table. If I were to add the revision prior to importing the blocks all seems ok. I have tried removing the block and deleting the definitions from the Inventor.dwg then re-inserting once more and I still have the same issue. The only real working solution I've found so far is to start from new and reproduce the drawings.
Has anyone else ran in to this problem?
Darek
Re: Issue With Imported AutoCAD Block disappeari ng.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-23-2012 10:07 PM in reply to:
ddavis
I will contact you through the support case I will be sending you.
Don
