• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Is this an error?
    135 Views, 3 Replies
    05-28-2012 02:44 AM
    Could someone please advise me what the lightening symbol means next to a bolted connection in an assembly.  Is it an error or nothing to worry about.  See attached JPG screen grab.
    Please use plain text.
    Distinguished Contributor
    Mason-Paul
    Re: Is this an error?
    05-28-2012 04:11 AM in reply to: rabruce
    Bolted Conection 43 Assembly file needs to be updated.
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
    *Expert Elite*
    PaulMunford
    05-28-2012 05:21 AM in reply to: rabruce
    Something in your assembly has changed, and the Bolted connection is telling you it wants to be updated.
    Right click on the Bolted connection and chose 'Edit with Bolted connection generator', Check the inputs and if all is well, just close the generator agin to update the Bolted connection.
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    *Expert Elite*
    Cadmanto
    05-28-2012 07:07 AM in reply to: rabruce
    Also try using the rebuild all command in the manage tab on the ribbon.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
