• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Is there such a thing as a global/default design view that can be applied?
    49 Views, 4 Replies
    11-25-2002 08:11 PM
    Being new users......
    We have made up a number of 'coloured' sub-assemblies. When these are amended and saved any other user that then opens the assembly does not get the colour changes (although any ammendments made to the structure of the assembly are ok).
    We seem to have narrowed it down to a design view issue, where each user has their own design view applied to the same assembly.
    What we really want is for each of us to see the assembly how it was last saved, including colour changes.
    In our 'simple' view a default design view for ALL assemblies would work very nicely but we can't see how to set one up?
    Please use plain text.
    *KJohnson
    Re: Is there such a thing as a global/default design view that can be applied?
    11-25-2002 08:39 PM in reply to: matkins
    The simplist way is to edit the parts and make the
    colour changes there.  Everyone will see the changes automatically
    then.  But if you do this delete the default.idv from each users
    directory.  The colour change there will override the colour of the
    part.  Good luck.
    Kathy Johnson
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Being
    new users......
    same assembly.
    how to set one up?
    *Caldwell, Larry
    11-25-2002 08:56 PM in reply to: matkins
    Not in a multi-user environment, but my
    assemblies don't change colors (well ... less I derive them). Does each user get
    the model back the way they last saved it, then; as opposed to the way the last
    user may have saved it? Do all the colors change or do the colors of parts with
    different materials change? Does everyone have the same colors applied to the
    different materials? The color is defined and attached at the ipt level I think
    so what ever color it is at ipt level should be the color everyone sees I would
    think.
    ~Larry
    Being
    new users......
    same assembly.
    how to set one up?
    *Caldwell, Larry
    Re:
    11-25-2002 09:01 PM in reply to: matkins
    Either it can't be 6:39 or the atomic clock I'm
    supposed to be synchronized with is whacked! <G>
    ~Larry
    the colour changes there.  Everyone will see the changes automatically
    part.  Good luck.
    Kathy Johnson
    Being
    new users......
    same assembly.
    Re:
    11-25-2002 09:11 PM in reply to: matkins
    Yes, each user does get back what they last saved in respect of colours. However, if someone puts a hole through a part (for example) everyone can see it.
    We don't want to colour the individual parts that make up the assembly as we have a number of common parts that are used in a number of different assemblies where the colours vary.
