Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Is there flexible part option in assembly?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a shaft for which i want to vary my diameter in the assembly without affecting the part.
Is it possible in Inventor?
Its there in ProE. Its called "Flexible".
Re: Is there flexible part option in assembly?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think you are looking for "adaptive" in Inventor.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Flexible is used for sub-assemblies within assemblies. Having a cylinder assembly that you want to stroke within assembly.
An adaptive part changes with repect to geometry referenced by another part within the assembly. If the shaft diameter is adaptive (projected geometry from a bore-hole), when the bore hole changes the diameter of the shaft will change.
If you want parts to change by tables, you might look at iParts.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 314.07
SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
@ above...
I dont want to use iparts. What i want is, as soon as i place a shaft in assembly mode it should ask for the diameter of the shaft in a dialog box. I should be allowed to change the diameter of the shaft without affecting the part.
For example: when we place a bolt from content center, it asks for the diameter in a seperate dialog box.
Is it possible?
If yes, then please upload the file.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
shuaib_cad wrote:... I should be allowed to change the diameter of the shaft without affecting the part.
In Inventor this makes no sense. The part is the shaft. Even with your example of a bolt from the Content Library, you make the selection, then the part gets created to that dimension.
If it is specifically a shaft that you want, you might look at the Design Accelerator for shafts. Or, you can create your own Content Library shaft that will allow you to choose dimension(s) before placement. But you can't change a component of an assembly without changing the model, because that's all the component is.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What you are asking about, is an iPart.
ITO - Application Management
Factory Design Suite Ultimate 2012
AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
@ above...
I am well aware about iparts.... but what i am asking is something else....
shaft was just an example.... what i want is as soon as i place a part it should ask for some specified dimensions of the part... when i give those inputs the part should be placed... but the orginal ipt should not change its dimensions...
its called flexible part dimension in ProE assembly.... i thinks its not possible in inventor....
coming to iparts... i have to create multiple parts in the ipt (which means if i want my diameter to vary between 50-100, then i have to insert 50 rows which in turn creates 50 ipt files).
If we have flexible part option to vary the part dimensions in assembly (like for content center) it would be easier and file size will be reduced.
If you know how to create such parts like conent center parts, please upload the file. it would be very useful for me.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can certainly create your own Content Library parts. You want to place as Custom, which allows specifying a dimension or dimensions rather than picking them from a table. I don't have any instructional materials, and I haven't done such a thing for a year or two, so someone else will have to jump in here. If you search in the Help and in this forum, I think you should search on Publish to Content Center (or Library), and also Part Authoring.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Create a new assembly and try placing the attached ipart.
Browse to save new file.
Set your dims.
Click in the window.
Dismiss.
Does this do what you want?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
shuaib_cad wrote: coming to iparts... i have to create multiple parts in the ipt (which means if i want my diameter to vary between 50-100, then i have to insert 50 rows which in turn creates 50 ipt files).
Those 50 parts are still derived from a single base part. Any changes you make to the base part will be reflected in all of its derived iParts.
Also, Content Center parts are iParts. Each time you place a component from the content center or change its size, Inventor checks to see if the iPart with the specified dimensions has already been created, and if not, it creates a new iPart file.
