• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Is it possible to set the drawing Scale to the Title Block?
    915 Views, 8 Replies
    10-26-2011 02:53 PM
    Hello
    Seems like it is missing parameter...
    Orest
    Please use plain text.
    Active Member
    sambaxter23
    Re: Is it possible to set the drawing Scale to the Title Block?
    10-26-2011 05:38 PM in reply to: Orest_iy
    Do you mean to do something along the lines of automatically set the scale value in the title block to the first base view? So that the value in the title block is dynamically updated with the base view?
    10-26-2011 11:40 PM in reply to: sambaxter23
    No
    Here is much more simple task.
    I just want to see the actual drawing Scale in my Title Block but did not find this variable in any
    of Drawing properties list.
    Orest
    Product Support
    alessandro.gasso
    10-27-2011 01:43 AM in reply to: Orest_iy
    Hi Orest,
    If what you can read in our blog post below is not what you are asking for, please, provide more details.
    Base view scale in title block
    Thanks and regards,
    Alessandro
    Alessandro Gasso
    Product Support Technical Lead
    MFG - Inventor
    10-27-2011 02:32 AM in reply to: alessandro.gasso
    Alessandro
    Thank you, it works!!!
    Best regards,
    Orest Yavtushenko
    10-27-2011 12:10 PM in reply to: alessandro.gasso
    Thank you for this.
    Stuart Kinzel
    Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
    8GB memory
    Windows 7 64bit
    Talayoe
    12-18-2011 06:21 PM in reply to: sambaxter23
    Sorry to revive an old completed thread, but it got my interest. I would like to know how one can accomplish this. I have my title block setup nicely. But on A size it goes off the paper a little, and on F size its so small you can barely read it.
    How would one go about setting a scale factor based on sheet size to the title block?
    tks!
    Inventor 2013 PDS
    *Pro
    12-19-2011 04:35 AM in reply to: Talayoe
    We use two title blocks-- one for A & B size sheets, the other for C, D, & E.  They're pretty much identical, except that the smaller one is scaled to 3/4 the size of the larger.  Since they are almost never edited, that doesn't cause too much pain.
    I suppose you could create a user parameter and have every dimension in your title block definition include that parameter as a multiplier, so you could set the scale for each drawing as you wish.  However, it would be difficult (impossible?) to change text size that way.  But, with iLogic there are nearly infinite possibilities, so you might look into that also (iLogic automatically chooses the correct border and title block for us when we tell it what size sheet we will be using).
    Valued Contributor
    12-05-2012 12:35 PM in reply to: Orest_iy
    Reviving an older thread, is there a way to add this to just one title block and have it get the base view PER SHEET? Our drawings never have a "regular" number of sheets. One may have one sheet and another may have 30. I can't be making 30 different title blocks and whatnot. Thanks.
