• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    GavoGarmo
    Is it possible to export selected colums of a BOM to excel?
    328 Views, 3 Replies
    11-28-2012 03:37 AM
    I would like to be able to export the description column of a BOM to an excel file, and exclude all the other data. I can't see any reference to doing this in the API. We have almost 20 columns so deleting them once the file is made is a bit of a pain.
    Thanks for any help.
    Please use plain text.
    Re: Is it possible to export selected columns of a BOM to excel?
    11-28-2012 11:59 AM in reply to: GavoGarmo
    To do this manually you may want to have a temporary BOM editor view xml file and a normal BOM editor xml file.
    Export your normal editor view setting to an xml file.
    Remove all the unwanted columns from your editor view, then export that as a temporary xml.
    Save out the single column to excel.
    This way you can import the temporary xml file to remove the columns.
    Then re-import your normal column layout to reset the columns.
    Slightly quicker than excel edit but not automatic sorry.
    hth
    Curtis_Waguespack
    Copy and Paste Column in BOM XLS
    11-28-2012 03:13 PM in reply to: GavoGarmo
    Hi GavoGarmo,
    Here is a quick ilogic rule to do this. In this example the BOM is exported to an XLS file and then Column D is being copied from the original XLS sheet into a new XLS sheet, then the original sheet is being deleted.
    You can refer to this link to see how a basic rule is created, if iLogic is new to you:
    http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
    I hope this helps.
    Curtis
    ' a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    oXLS = "C:\temp\BOM-StructuredAllLevels.xls"
    oDoc = ThisApplication.ActiveDocument
    'set  a reference to the BOM
    Dim oBOM As BOM
    oBOM = oDoc.ComponentDefinition.BOM
    'set the structured view to 'all levels'
    oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    'set a reference to the "Structured" BOMView
    Dim oStructuredBOMView As BOMView
    oStructuredBOMView = oBOM.BOMViews.Item("Structured")
    ' Export the BOM view to an Excel file
    oStructuredBOMView.Export (oXLS, kMicrosoftExcelFormat)
    'define Excel Application object
    excelApp = CreateObject("Excel.Application")
    'set Excel to run visibly
    'change to false if you want to run it invisibly
    excelApp.Visible = True
    'open the workbook
    wb = excelApp.Workbooks.Open(oXLS)
    'set all of the columns to autofit
    excelApp.Columns.AutoFit
    'suppress prompts (such as the compatibility checker)
    excelApp.DisplayAlerts = false
    'add a new sheet to the xls file
    excelApp.sheets.Add.Name = "Sheet1"
    'select the original exported sheet
    excelApp.Sheets(2).Select
    'select range to copy
    excelApp.Columns("G").Copy
    'select sheet to paste to
    excelApp.Sheets("Sheet1").Select
    'select range to paste to
    excelApp.Columns("A").Select
    'paste the selection
    excelApp.ActiveSheet.Paste
    'reset selected cell to A1
    excelApp.Cells(1,1).Select
    'delete the original sheet
    excelApp.Sheets(2).Delete()
    'save the workbook
    wb.Save
    ''close the workbook, uncomment if you want to close the xls file at the end
    ''wb.Close
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Distinguished Contributor
    Re: Is it possible to export selected colums of a BOM to excel?
    12-04-2012 01:59 PM in reply to: GavoGarmo
    Are you exporting from the Bill Of Material or from a Part List?  If you export from a Parts List, from within a drawing, you can chose what columns are exported by clicking on the OPTIONS button in the Export Dialog Box.  Or you could define a Parts List Style with only the columns you want to export.  This may be an annoying extra step if you don't already have drawings with a Parts List for the assembly.
    Stuart Kinzel
    Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
    8GB memory
    Windows 7 64bit
