Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Is it possible to create sheet metal part by mirroring?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
I have a sheet metal part. It is a machine door with four edge flanges.
I have mirrored this part.
The origin part has flat pattern while the mirrored creates the folded pattern.
It still folded even when origin is in flat pattern.
Please advise does it mean I cannot create full sheet metal part by mirroring?
Orest Yavtushenko
Re: Is it possible to create sheet metal part by mirroring?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You create the mirrored sheet metal part be deriving component and selecting the mirror option.
Be sure to set the Style to correct thickness.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yeah, it is working this way.
Thank you for good avice.
Best regards,
Orest
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Orest_iy,
Is sounds as if you're mirroring the part in the assembly?
Another approach is to mirror at the part level. If you open the original part and save it as a copy and then use the Mirror tool and choose the Mirror a Solid options with the Remove Original checkbox selected, you should be able to get what you're after.
You might also want to edit the flat pattern orientation once it's mirrored:
http://inventortrenches.blogspot.com/2011/05/edit-
I've attached a couple of example files, where the Left version was the original and the Right version is the copy.
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Curtis
It works well too.
Once I need a part to exactly follow a master as for instance I have with my doors,
but sometimes I need a mirrored copy and this way makes it instantly without refolding
everything back to 180 degrees..
Thank you for advise
Orest
