• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Is it possible to change parameter value of derived sketch block?
    101 Views, 0 Replies
    11-02-2012 09:23 AM
    This may require a more advanced feature, but if I use sketch blocks, and have a part that derives and imports these blocks, is it possible to make these flexable by changing a paramter of the sketch block?  For example if I have a sketch block that uses stock_thickness to be define various dimensions, and I want to use sketch block, but I need to change this stock_thickness.  If this is more than sketch blocks are used for, what can I use for this?
    Thanks.
    Please use plain text.
