• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Inventor studio
    211 Views, 9 Replies
    04-27-2012 07:57 AM
    I create a engine assembly and used "Drive Constrain" to rotate the crank shaft. The animation shows the crank shaft turns continuously in one direction. However, when I animate the constrain in Inventor Studio, the crank shaft turned in two different directions (see the vide file attached).
    May I know why the crank shaft turns different direction?
    Please use plain text.
    Re: Inventor studio
    04-27-2012 08:15 AM in reply to: lis_wang
    Which of the 3 Angle Constraint types did you use?
    Can you use Dynamic Simulation and Publish to Studio instead?
    Re: Inventor studio
    04-28-2012 12:43 AM in reply to: JDMather
    Not matter I used Directed Angle or Undirected Angle, it is still the same. I created a animation by using "Drive Constrain"  and the crank shaft shows only one direction. Please see the file attahced.
    Re: Inventor studio
    05-01-2012 05:58 AM in reply to: lis_wang
    Any reply?
    Re: Inventor studio
    05-01-2012 06:32 AM in reply to: lis_wang
    Attach your assembly here.
    Re: Inventor studio
    05-01-2012 07:01 AM in reply to: JDMather
    As the file is too big, so I zipped into 3 files. This is the 1st zip file.
    Re: Inventor studio
    05-01-2012 07:02 AM in reply to: lis_wang
    This is the 2nd one
    Re: Inventor studio
    05-01-2012 07:04 AM in reply to: lis_wang
    This is the last one. Please unzip the 3 zipped files into one folder.
    Re: Inventor studio
    05-01-2012 07:25 AM in reply to: lis_wang
    Make sure the planes used for the angle constraint share the same axis.
    I used the assembly origin YZ and the DLM-006 YZ planes for the angle constraint and it worked fine in Studio.
    Re: Inventor studio
    05-01-2012 06:36 PM in reply to: JDMather
    Thanks. It solves my preoblem.
