• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    jacob.gondek
    Inventor project file keeps switching to default
    217 Views, 2 Replies
    09-25-2012 05:50 AM
    I run inventor with Vault. I have a project file set up in my vault directory. Each time I close everything and restart my computer inventor switches the Project back to default. I have deleted every .ipj I could find. Below is a screen shot of what I see every morning. It should be on vault but it is not. If I start by checking out a file from vault it checks it back in because the .IPJ is not set in inventor. Does anyone else have this problem?
    Please use plain text.
    karthur1
    Re: Inventor project file keeps switching to default
    09-25-2012 06:00 AM in reply to: jacob.gondek
    Product Support
    innovatenate
    10-09-2012 12:48 PM in reply to: jacob.gondek
    In the Tools ribbon > Application Options > File tab > the "Projects folder" directory usually contains shortcuts to the project files listed in the project editor. If you browse to that location, do you see a shortcut associated to the VAULT.ipj?
    Do you have read/write access to the "Projects folder" directory?
    Nathan Chandler
    Product Support Specialist
    Product Support Americas
