• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Inventor picture becomes too dark
    192 Views, 13 Replies
    04-27-2012 11:21 AM
    Hello
    My Inventor screen picture became much dark as used to be.
    For example all my aluminum parts became too dark and too grey.
    My office machine has excellent picture within the same settings of Lightings.
    Here is video link attached. If I set more Bright the picture becomes closer as used
    to be but it used to work fine at 50% and my office machine is also perfect at 50%
    Please advise ether it about the setting of Inventors or my videocard ?
    I've got this problem after the successive series of program crushes.
    There is only Inventor has this "dark picture" problem. Other programs works fine.
    Inventor reinstallation did not help.
    Please help,
    Orest Yavtushenko
    Please use plain text.
    Product Support
    Re: Inventor picture becomes too dark
    04-27-2012 04:06 PM in reply to: Orest_iy
    Orest,
    I did not see your video link. You also don't state what version of Inventor you are on.
    So you checked the definition of the lights in the Style editor and they have the correct intensity?
    Bob
    04-27-2012 11:25 PM in reply to: bobvdd
    Ouch
    Here it is
    http://www.screencast.com/t/oMFXQKmw
    Yes it is the correct setting in Lighting style.
    And I used to have a nice picture prior to crush
    If I switch from Two Lights to Default and other settings they are also dark.
    It seems like some one more general Lighting correction exist and it is located in front
    of all other setting affeting them all.
    For example I should set Brightness aprox 70% at my laptop now while my office machine
    within this shining more than too much..
    Orest
    trumpy81
    04-30-2012 03:53 AM in reply to: Orest_iy
    Orest_iy, are you aware that most laptops operate with reduced screen brightness, to save power?
    This may explain why your desktop machine looks great but the laptop does not. Try adjusting the screen brightness on the laptop. This may be a BIOS setting or a Video card driver setting or simply a control panel/Display setting.
    If you run your laptop on battery power at all, that will also have an impact on screen brightness.
    My suggestion would be to live with the default styles, and remind yourself that you are working on the laptop :smileysad:
    Regards
    Andy M
    Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
    Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
    1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
    04-30-2012 07:29 AM in reply to: trumpy81
    Hmmm
    It could be the reason but I have only the working window of Inventor dark.
    The Inventor ribbons, browser and other programs works fine.
    I do not think the ability of  laptop to save a power in this selective way is so advanced...
    Either way all possible setting of my nVidia card I set to default or to disable.
    The choice of aplication vs nVidia guiding the screen does make any difference.
    For instance my prewiew pictures of files I did not touch after this problem are much more bright
    compare the files saved now..
    Orest
    04-30-2012 07:35 AM in reply to: Orest_iy
    What are your settings in tools..application options..hardware tab? (on both computers)
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    04-30-2012 07:54 AM in reply to: mcgyvr
    In the Application Options - Display
    I have tried both aplication and document setting.
    I the Document Settings - Standard - Settings I have the same light settings
    I have restarted the Inventor each time of setting were changed.
    If I switch between Default - Two Light and other - all are much more dark as used to be
    Both PC has same settings.
    I prefer application setting so the Inventor will dictate the Light but not the current file.
    After this problem I've tried probably all possible combinations and even reinstall the Inventor
    trumpy81
    04-30-2012 08:12 AM in reply to: Orest_iy
    Is this happening with just this one document, or does it happen with all documents?
    Regards
    Andy M
    04-30-2012 08:18 AM in reply to: trumpy81
    All files of all projects became dark.
    It is really like some setting are located BEFORE all existing in Inventor
    and something turn them 30-40 prcent down
    trumpy81
    04-30-2012 08:35 AM in reply to: Orest_iy
    When you Installed Inventor on the laptop and opened the files for the first time, did you get a message dialog asking to convert existing styles to appearances?
    Regards
    Andy M
