• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    huntoon
    Re: Inventor on Mac via Parallels Desktop
    06-30-2011 08:35 AM in reply to: cmcconnell
    I just checked out your website. Looks like you do really good work.
    I had one question though, what is that Terminator-snake thing?!Screen shot 2011-06-30 at 8.33.02 AM.png
    Please use plain text.
    Distinguished Contributor
    06-30-2011 11:25 AM in reply to: huntoon
    Ha ha. That is a pipeline Inspection tool (PIG for short). That particular one is for 6" pipe. It is pushed through the pipeline by the product and it measures and logs geometry and corrosion.
    Mechanix Design Solutions inc.
    New Member
    06-08-2012 06:21 PM in reply to: cmcconnell
    cmcconnell - I am curuios as to what settings you are using w/ in parallels? How many CPU's do you assign? How much memory? Do you keep Windows Aero activated?
    I too have a new MacBook Pro w/ 8GB ram, and 2.2 GHz i7 Processor. I am running Windows 7 - 64bit on Parallels Desktop 7.
    Any other pointers would be greatly appreciated.
    Thanks.
    New Member
    Settinglake
    06-11-2012 01:59 PM in reply to: yeqmaster
    Hi - I definitely have turned Aero off.  I let parallels take the max ram it needs.  I only have one CPU dedicated.  I disable as much of Windows 7 as I can.
    For the most part My laptop is pretty stable.
    We also run Mac Pro boxes under bootcamp.  That works pretty well except there are a lot of updates required to get Windows 7 to run out of the box.
    Doug
    Member
    07-21-2012 11:33 AM in reply to: huntoon
    I've just installed Inventor Pro 2013 on my MacBook Pro running OS X 10.7.4 and Parallels 7.0.15055.  Most everything appears to work properly except things like the delete key don't work.  I have to press Shift-Ctrl and then select Delete to get rid of drawing elements.
    Have any of you had this difficulty?  Is there a way to make the Delete key work in the standard way?
    In advance, thanks for your advice!
    Member
    07-21-2012 11:40 AM in reply to: g.desbrisay
    Hey, I just found the answer after juggling my search terms on this list a bit!:
         Re: Deleting...
         11-28-2011 01:19 PM in reply to: willsutcliffe
         Additionally, on Mac keyboards which only have the Backspace key, you can make it work
         like a normal Delete key by pressing the Fn (function) key along with Backspace.
         Zac Travis
         Autodesk Product Support
    Thank you Zac Travis!
    Greg
    07-21-2012 03:28 PM in reply to: g.desbrisay
    Does holding the function key and pressing delete key help? Cory McConnell www.mechanixdesigns.com
    Member
    07-22-2012 10:04 PM in reply to: cmcconnell
    Yes, that's it!  Fn-<Delete> works on the Mac keyboard.
    07-23-2012 04:21 AM in reply to: g.desbrisay
    You will find that you can use the fn key to get many of the keys you are used to on a regular windows keyboard. Like fn and the right arrow key is END.. Etc Cory McConnell www.mechanixdesigns.com
