Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Inventor changes to cm instead of mm?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Using Inventor 2012 Premium, this problem didn't exist in 2011.
When I click "I"->New(small arrow)->Part. All dimensions are in cm.
If I instead click "I"->New and choose the Part template all dimensions are in mm, as it should. I have two .ipt-templates (standard (mm) and sheet metal (mm))
My college went through all templates we have and no one uses cm.
This is driving me crazy, can anybody help me?
Re: Inventor changes to cm instead of mm?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi GustavStigsohn,
When you click "I"->New(small arrow)->Part, Inventor uses the template found at the root of your template directory called Standard.ipt
You can open your mm template, and use the Save As > Save Copy As Template option to save it as Standard.ipt (replacing the existing Standard.ipt template). Then when ever you use the "I"->New(small arrow)->Part method, you will start off with a mm template.
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the answer!
My template directory is set to G:\Blabla\cad\Templates\2012\ under application options>file>default templates.
In that folder we have "Standard (mm).ipt" and "Sheet metal (mm).ipt" both uses mm (those are the only .ipt). Still it uses cm when I click as described above.
We have the same problem with .iam but not dwg.
Is it possible to see which template that is used in a part?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi GustavStigsohn,
If you don't have a file called Standard.ipt in the root of your template directory and you use the drop down list, then Inventor defaults to a template that is hardcoded withing in the program (if I recall correctly). So I think the best solution is to place a copy of your mm template in the root of your template directory and name it Standard.ipt, or just rename you existing template Standard.ipt
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Renamed the template and now it works!
Many thanks!
