• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    jz4all
    Inventor and Inventor Fusion?
    456 Views, 3 Replies
    11-13-2012 11:25 PM
    Hi
    Short time ago I got update to my AutoCAD from 2010 to 2013. I got within the paket (Inventor fusion).
    I did never use Inventor. I would like to know what is the difference between Inventor and Inventor Fusion?
    Can somebody explain that to me or give me a link where I can find the good answer?
    thanks
    Please use plain text.
    Re: Inventor and Inventor Fusion?
    11-14-2012 05:10 AM in reply to: jz4all
    Fusion is free http://labs.autodesk.com and yet apparently nobody uses it (as evidenced by the lack of responses to your post here http://forums.autodesk.com/t5/Inventor-Fusion/what-is-the-difference-between-Inventor-and-Inventor-F...).
    Inventor is an expensive, professional program http://store.autodesk.com/store/adskus/en_US/pd/ThemeID.23155600/Autodesk_Inventor_Professional_2013...
    as evidenced by the number of posts in this forum in the same time period since you Fusion forum posts there are significantly more people willing to pay to learn and use Autodesk Inventor.
    You can see Fusion demonstrations here http://au.autodesk.com/?nd=classes&filter_keywords=&chunk=15&filter_material=&filter_personal=&filte...
    Now I'm sure someone from Autodesk will come along and explain the difference between history-based parametric modelers and direct modelers..... ....just the facts.
    Inventor Professional 2014 Edu 64-bit
    jz4all
    11-14-2012 05:23 AM in reply to: JDMather
    Thanks a lot :smileyhappy:
    Valued Mentor
    jclaidler
    11-14-2012 12:34 PM in reply to: jz4all
    http://labs.autodesk.com/technologies/fusion/
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
