• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Mentor
    stephengibson76
    Inventor and AutoCAD sheet sets
    138 Views, 2 Replies
    07-18-2012 02:50 AM
    Is there a way to link sheet sets in autoCAD with Inventor idw's?
    Basically we do the initial design in Inventor then basic drawings and drop them into AutoCAD to detail up at a later date.  The crossover timing to autocad is always contensious because we break the link with the model.
    we need to issue draft drawings from inventor so the titleblock etc needs to be filled in correctly and we are looking for a way not to redo the work in autocad but also use the sheet set manager
    Stephen Gibson
    Autodesk Product Design Suit 2012
    Win 7 Enterprise 64bit
    Intel core i7 2600K Clocked @ 4.7GHz
    16Gb Ram
    Nvidia GTX 580
    Please use plain text.
    Curtis_Waguespack
    Re: Inventor and AutoCAD sheet sets
    07-18-2012 08:30 AM in reply to: stephengibson76
    Hi stephengibson76,
    You can't use AutoCAD sheet sets with IDWs, but you can if you convert the IDW to an Inventor DWG file. Recall that an Inventor DWG is just like an IDW but with added funtionality.
    http://inventortrenches.blogspot.com/2011/05/using-autocad-sheet-set-manager-with.html
    http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0074-Getting_74/0115-Document115...
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Mentor
    stephengibson76
    07-18-2012 08:55 AM in reply to: Curtis_Waguespack
    Thanks,  this seems to work quite well and also creates a buffer so the drawings remain associated to the model for longer before they are autocadded out and link broken
    Any problems with inventor dwg's other than filesize?
    Stephen Gibson
    16Gb Ram
    Nvidia GTX 580
