• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Re: Inventor View Font
    11-28-2006 06:38 AM in reply to: klange
    Tahoma - I believe Inventor defaults to this font. We have not changed it.
    HP LaserJet 8100
    Please use plain text.
    Distinguished Contributor
    11-28-2006 09:34 AM in reply to: klange
    What version are you using? I had a similar problem at some point with IV10. There was some sort of update to correct the problem.
    Inventor Routed Systems 2010
    Subscription Advantage Pack SP3
    Vault Collaboration 2010
    Windows 7 x64
    Dell Precision M6400 Covet
    Active Member
    11-28-2006 12:14 PM in reply to: klange
    IV 11. There are updates available for Inventor View as well, but they do not resolve the problem.
    Active Member
    11-28-2006 12:19 PM in reply to: klange
    I received this information from an Autodesk support technician...
    I have done some additional research and have found the following information.
    This is a known issue with the viewer. When translating the text, the viewer is taking it from a much larger area than Inventor and it tries to maintain the aspect ratio. In doing this, the fonts can get cramped together or even run on each other.
    I don't have an ETA on a change in behavior for this or even if it will be changed. The whole thing to remember is that the viewer is just that, a viewer - not meant to necessarily print the files, however I can imagine the need for a QA technician, etc. to want to do that.
    The only workaround at this time is re-scaling it from the viewer to make the change in text appearance less noticeable.
    11-28-2006 12:41 PM in reply to: klange
    "The whole thing to remember is that the viewer is just that, a viewer - not meant to necessarily print the files..."
    Did you make up that part?
    Windows 7 x64
    Active Member
    11-28-2006 12:45 PM in reply to: klange
    That came straight from the support tech. Sounds like they don't know how to fix the problem and are using technicalities as excuses.
    12-20-2006 01:36 AM in reply to: klange
    This just in, not my own work, discovered on another forum
    Change your default printer settings (via Control Panel) to match the desired output, then print using the default printer in Inventor View and all the font issue suddenly clear up.
    It seems that if you change the printer settings from within Inventor View, it still tries to use the settings of the default print, but sends them to the selected printer.
    Regards
    MattH
    12-20-2006 05:33 AM in reply to: klange
    This might be the same thing, but we've noticed that you need to use page setup in IV View in order to get a decent print. Changing options in the print window doesn't work so well.
    Windows 7 x64
    04-17-2012 07:43 AM in reply to: klange
    Thanks for this solution!  It has helped a lot.
    Dan
    www.yf.com
    www.tactair.com
