• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Inventor View 2013 silent installation
    915 Views, 1 Replies
    04-10-2012 02:14 AM
    I have a problem to deploy the 2013 Version of Inventor View. (german)
    To install the application i use the msi file which is stored in the folder "x86\inventorview\" in the installation package.
    This works after i delete one row in the msi file with the tool "orca". (removed the exe launch condition)
    When I try to start the application after the installation, I receive the error "ApprenticeRegSvr has stopped working".
    After this error message I recieve "Inventor View stopped working".
    I was able to deploy the 2012 Version successfully and use the same procedure for 2013.
    When I install the application with the setup.exe it works.
    (I also install all 3rd party applications which are required.)
    Any ideas?
    Please use plain text.
    New Member
    klapproth
    Re: Inventor View 2013 silent installation
    06-06-2012 07:20 AM in reply to: thomas_010
    Same problem here. It seems the UI-less installer misses some files. I manually copy the missing files per GPO.
    From autodesk_inventor_view_r2013_german_win_64bit\x64\de-DE\InventorView\Program Files\Autodesk\Inventor 2013\Bin\Bin32\de-DE copy SrvRes.dll , UTxRes.dll , RSeRes.dll to %ProgramFiles%\Autodesk\Inventor View 2013\Bin\Bin32\en-US
    Copy every file from autodesk_inventor_view_r2013_german_win_64bit\x64\de-DE\InventorView\Program Files\Autodesk\Inventor 2013\Bin\Bin32\de-DE to %APPDATA%\Autodesk\Inventor View 2013\Bin\en-US without overwriting any file (use target rule: CREATE)
