Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Inventor Sping creation Issue
- Highlight
- Email to a Friend
- Report Inappropriate Content
Its about the extension spring created by Inventor.
No matter using the spring feature in design accerelator or coil feature, i am unable to create the spring wire of the coil touching each other, that means no gap in between. ( refer to the attachment)
In actual, the turn of the spring is touching each other.
In Inventor case, I cannot prepare technical drawing basing on the solid I created in Inventor, it will be longer than actual and the pretension of the spring is gone if there is a gap between the turns. It means, if spring were produced base on Inventor’s drawing, the tension will be very very low then actually intended for.
Can you have a look and let me know how to overcome this problem
At present,If I use MDT to create the spring and generates tech dwg. The MDT allow the turns to touch each other (that means no gap).
Re: Inventor Spring creation Issue
- Highlight
- Email to a Friend
You should be able to create a coil with a very small gap 0.000001 or smaller between the coil surfaces. The problem is with self-intersecting sweeps (coil) and surface contact. This small amount should still allow for the coil/sweep while being small enough not to affect your main dimensions.
This used to be a problem before the "Split-Surface" command, where we had to create a slightly different surface size to only apply a finish such as a Knurl to a specific area/region.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 320.18
SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
- Highlight
- Email to a Friend
Thanks for your reply.
