• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Re: Inventor Sketch Orientation
    02-17-2009 12:43 PM in reply to: mikeg
    Mike,
    A couple of questions/suggestions:
    1) go to Application Options and uncheck "Look at sketch plane on sketch creation.
    2) set your Constraint placement priority to "Parallel and perpendicular"
    3) Is there a particular reason you need a sketch CS aligned in a particular fashion? (We align parts to the part CS, but do not worry about aligning/rotating sketch CS).
    As far as the "problem", its not really so much of a "problem" as a choice. You will notice that if you have the "Look at sketch plane on sketch creation" selected, then when you make a sketch on one of the Origin planes, then it is oriented such that the Part CS has a vector pointing out of the screen, and another vector pointing "up". This is a reasonable choice and is consistant.
    My guess is that once you turn off the option to "Look at the sketch plane..." your troubles will go away cause you can just view as you see fit.
    Please use plain text.
    02-17-2009 12:45 PM in reply to: mikeg
    >The solution to your first problem is to set the sketch to which ever plane you want to be the default.
    or set to none (which is what we do). Depending on what we are drawing, we start on different planes.
    02-17-2009 01:33 PM in reply to: mikeg
    I'll add my 2 cents. I have to agree with Mike on this one, and would be curious to know why Inventor rotates certain "looked at" views / planes. It was confusing to me at first, and is fun when trying to explain to newer users why that horizontal line needs a vertical constraint and vice versa. I don't remember these issues when working with ProE or SW. I wonder if this is are part of the issue when redefining sketch planes. Sometimes it rotates them 90 deg which can be annoying, especially when a sketch on a similar plane has a different orientation.
    That said, I am pretty much used to it now, so it doesn't bother me much.
    On a side note, I think it was possible to chose which side of a plane you sketched on with ProE a number of years back. I vaguely remember that or something similar confusing a lot of people in the class.
    Pete
    *Igor Mironenko
    02-17-2009 04:24 PM in reply to: mikeg
    That's what I do too.
    Igor.
    or
    *Igor Mironenko
    Hi Mike
    For the first sketch you can realign the sketch CS
    by selecting Origin Axis's from the browser. I just tried it and it works. I
    agree with you that Look At tool should be a lot more user friendly than it
    is.
    Igor.
    Igor,
    for your input. I understand that each sketch has its own UCS and that I can
    change it. Well, I can if it's not the first sketch. As I said before, if it's
    the first sketch, there is nothing to realign it to. If Inventor let me align
    to the origin axes, that would help. But, I digress. I shouldn't have to do
    that at all. I hoped someone would tell me that I missed a setting somewhere,
    but that's not been the case.
    The problem still is that
    Inventor thinks the UCS of a sketch on the right plane needs to be rotated 90
    degrees and, even worse, why a sketch on the top plane needs to be turned
    upside down? I think the question has pretty much been answered, though. There
    is nothing I can do to make Inventor stop creating that problem. To me, it's
    just ridiculous and the most annoying of the everyday things I do with
    Inventor.
    Mike
    Active Member
    02-17-2009 08:11 PM in reply to: mikeg
    Igor,
    Yea. I just tried that in 2009. I worked fine. It didn't work in the other version I work with. I'll try it again tomorrow at work.
    Still, this absolutely should not be necessary
    Mike
    {quote:title=Guest wrote:}{quote}
    {font:Arial}{size:2}Hi Mike{size}{font}
    {font:Arial}{size:2}For the first sketch you can realign the sketch CS
    is.{size}{font}
    {font:Arial}{size:2}Regards,{size}{font}
    {font:Arial}{size:2}Igor.{size}{font}
    To reply please use href="mailto:igor@iinet.net.au">igor@iinet.net.au address
    <mikeg@goughecon.com>
    wrote in message href="news:6126255@discussion.autodesk.com">news:6126255@discussion.autodesk.com...
    Igor,
    Inventor.
    Mike
    Active Member
    02-17-2009 08:37 PM in reply to: mikeg
    Josh,
    First, thanks a lot for your comments. Unfortunately, there's nothing new there.
    1. That makes no difference whatsoever in the the orientation of the sketch UCS, it just doesn't show you what it is. I want it to look at the sketch when I create it and I want it to be right-side up, not rotated or upside-down.
    2. I don't want to use parallel and perpendicular. I prefer horizontal and vertical. It's a configuration option and it should work right. Actually it does, but the sketch UCS's are screwed up.
    3. Yes. All sketches should be created with the part remaining right-side up. They aren't, which is absolutely absurd.
    No, it's not a choice, it's a problem. I don't have a choice. Turning off "look at sketch..." only masks the problem. It doesn't fix it. It's not a reasonable choice at all.
    It's also definitely not consistent. I can create a sketch on the XY plane, which Inventor turns upside-down. If I create some geometry on that sketch, extrude it up, then create a new sketch on the top of the new solid, it creates the sketch right-side up. Sketches created on parallel planes are created 180 degrees apart. That's hardly consistent.
    I've been using Inventor for a long time. This has been screwed up at least since version 5. I realize that I must forget about it and move along. Autodesk obviously doesn't think anything's wrong. Ignoring the problem, by turning off the "look at sketch..." option, doesn't make it go away.
    Thanks again for your comments,
    Mike
    Active Member
    02-17-2009 08:50 PM in reply to: mikeg
    I'm not just starting to use Inventor. I've used both SW and AIS for several years. I love and hate both of them at different times.
    I don't have a problem with which sketch is first. I have the automatic sketch creation option turned off altogether and have for several versions now, since I first started using Inventor. I create my first sketch myself on the plane that best suits the part I'm working with. No way that Inventor can predict that. I don't know how that got perceived as a problem in the first place. I surely didn't say it was.
    Also, like I've told many others, this has nothing to do with the View Cube or it's settings. It's a sketch UCS issue. Nothing more, nothing less.
    Thanks for trying,
    Mike
    Active Member
    03-10-2009 12:35 PM in reply to: mikeg
    I see this discussion went away without an answer, specifically from Autodesk. I see them all over the place in these message boards, but not here.
    Curious. Could it possibly be that nobody at Autodesk knows how to fix this because it can't be fixed? I'm beginning to think that's the case. Still it's absurd that they won't just admit that. They really should do one of the following:
    1. Tell us how to fix this problem.
    2. Tell us that they can't fix this problem.
    3. Tell us that it's supposed to be that way, but include the reason why.
    I don't think that's a lot to ask.
    Mike
    Member
    03-11-2009 01:58 AM in reply to: mikeg
    Hi Mike,
    I think you can change default template into DIN template to resolve the issue.
    Steps:
    1)Check on "Look at sketch on sketch in sketch Tab Creation and Sketch on y-z plane in Part Tab;
    2)Select Standard(DIN).ipt as template in Metric tab,please refer to 1.JPEG;
    thanks
    Robert
