• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Inventor Rendering using Autodesk 360
    336 Views, 6 Replies
    06-07-2012 11:36 AM
    I am a subscription user on Factory Design Suite and am hoping to use Autodesk 360's online rendering capabilities so that I am not tying up my desktop for hours while it is producing an image.  While on rendering.360.autodesk.com, I only saw options to load AutoCAD dwg's or Revit files.  Is there no way to produce a rendering using 360 of an Inventor file or am I missing something?  Any help would be appreciated.
    Please use plain text.
    Mark_Flayler
    Re: Inventor Rendering using Autodesk 360
    06-07-2012 12:22 PM in reply to: micah.milliman
    You have to do it with 3Ds Max Design or with Showcase (there is an option to render in cloud and local).
    Mark Flayler Application Engineer - Manufacturing Solutions Division
    IMAGINiT's Manufacturing Solutions Blog:
    http://blogs.rand.com/manufacturing/
    New Member
    09-18-2012 12:06 PM in reply to: Mark_Flayler
    Where exactly do you go in 3dsMax to render using 360 cloud?  Far as I know you can only render Revit and Autocad files in the cloud.
    DarrenP
    09-18-2012 12:36 PM in reply to: neilg
    he is saying use 3ds max to make the rendering there is no cloud option in 3ds max
    Mark_Flayler
    09-18-2012 03:40 PM in reply to: micah.milliman
    Yea, I should clarify, in Showcase you can publish your movie directly to the cloud, but it doesn't render it.
    With 3Ds Max you can do some high end rendering on a render farm of computers but it needs to be put into Max and then adjusted for lighting and cameras.
    For Inventor animations you are pretty stuck if you are using Inventor Studio.  You might want to check out FactoryModz on the labs website though if you are looking for animation of product.
    Active Contributor
    09-18-2012 07:50 PM in reply to: micah.milliman
    The Factory.Modz animation tools are only for Inventor Factory and don't really provide tools useful in Inventor itself - as far as I can tell. So, the statement, Inventor Studio, 3ds max, or Showcase is accurate. Those are your render choices. Each having pros/cons.
    -Bill Bogan
    just one man's opinion...
    Bill Bogan
    - Providing freelance visualization
    - Inventor: Expert
    - Revit: Novice and growing...
    Employee
    09-25-2012 01:16 AM in reply to: micah.milliman
    Factory Modz. can work on Inventor 2013 and FDS 2013, but yes, it only animate the specific assets which Factory product is providing such as the Robot, Generator, Line sensor, forklift etc.
