• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    philipmetseam
    Inventor Registry?
    1000 Views, 11 Replies
    09-06-2010 02:08 AM
    Hello Donal,
    When i run Inventor this is what happens:
    • Windows Message:
    Registration of Inventor.exe
    Inventor.exe needs to reregister with the operating system and the following programs (Explorer) are running and may prevent registration from successfully completing.  Autodesk recommends terminating the offending processes to ensure proper registration.  Terminate the processes before continuing with the registration?
    AT THIS POINT I CAN SELECT Yes, No or Cancel.
    I click on Yes (However i tried clicking on other two options, nothing changed) and i make sure that all programs are closed.
    • Windows Error Message:
    Autodesk Inventor LT 2001: Inventor.exe – Entry Point Not Found
    The procedure entry point GetProcessHandleFromHwnd could not be located in the dynamic library OLEACC.dll.
    AT THIS POINT I CAN ONLY SELECT “OK”.
    • Windows Message:
    Autodesk Inventor LT 2011
    Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\DI.dll.
    • The Windows Error Message (Point 2) is repeated.
    • Windows Message:
    Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\DtExt.dll.
    • The Windows Error Message is repeated three times.
    • Windows Message:
    Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\MbUI.dll.
    • The Windows Error Message is repeated twice.
    • Windows Message:
    Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\Nb.dll.
    • The Windows Error Message is repeated.
    • Windows Message:
    Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\DIDwg.dll.
    • Windows Message:
    Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\DWGExt.dll.
    • Windows Message:
    • Windows Message:
    Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\Pf.dll.
    • Then the Autodesk Inventor Error Report comes up.  I have filled this in, but never got a response.
    Can you help me?  Or inform me who i can contact to solve this?
    Philip Hamilton
    Philip Hamilton
    Estimator and Technical Advisor
    Met-Seam Ltd, Silverwood Industrial Estate, Craigavon, Northern Ireland, BT66 6LN
    Tel:  +44 28 3832 5757  Fax: +44 28 3832 5758
    Mobile: 0775 4463 967   e-mail: philip@metseam.com   Web: www.metseam.com
    This e-mail is only intended for the person(s) to whom it is addressed and may contain confidential information. Unless stated to the contrary, any opinions or comments are personal to the writer and do not represent the official view of the company. If you have received this e-mail in error, please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person. Although this email and attachments are believed to be free of virus, or any other defect which might affect any computer or IT system into which they are received and opened, it is the responsibility of the recipient to ensure that they are virus free and no responsibility is accepted for any loss or damage arising in any way from receipt or use thereof.
    Thank you for your co-operation.
    ****Sage
    Re: Inventor Registry?
    09-06-2010 05:07 AM in reply to: philipmetseam
    philipmetseam wrote:
    Hello Donal,
    Not sure where that came from, but -
    ...what is your OS?
    If Vista or Window 7 did you turn off UAC before install?
    Try turning off now and reboot.  Click yes to the registry message.
    If no change,
    try a Repair Install
    if still no change
    try a clean uninstall/reinstall.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14893355&linkID=9242018
    Autodesk Inventor Certified Professional
    Inventor Professional 2012 Edu 32-bit
    Still waiting for -Draft option on any Rib feature. -Properties Painter.
    Still wondering why Edit Form is above Edit Feature on RMB?
    Active Member
    philipmetseam
    09-06-2010 05:13 AM in reply to: philipmetseam
    Thank you.
    I have already tried all this.
    The OS is XP.
    Any other suggestions?
    Thanks again.
    Philip Hamilton
    *Pro
    09-06-2010 05:32 AM in reply to: philipmetseam
    What antivirus do you have?   Was it off during the install?
    Mark Flayler
    Application Engineer - Manufacturing Solutions Division
    IMAGINiT's Manufacturing Solutions Blog: http://blogs.rand.com/manufacturing/
    Active Member
    philipmetseam
    09-06-2010 05:37 AM in reply to: Mark_Flayler
    AVG and it was off during the install
    Philip Hamilton
    *Pro
    09-06-2010 05:56 AM in reply to: philipmetseam
    Since this is an XP machine, do you have a SSE2 complient processor?  I used to see a problem based on this on older Intel or AMD processor structures.  How about you list all your system specs here to rule out most of these hardware issues.
    Type in MSINFO32 in your run box and report on those results.
    Report on the main screen and the Components>Disply information.
    Mark Flayler
    Active Member
    philipmetseam
    09-06-2010 06:20 AM in reply to: Mark_Flayler
    OS Name Microsoft Windows XP Professional
    Version 5.1.2600 Service Pack 3 Build 2600
    OS Manufacturer Microsoft Corporation
    System Name DG9LV84J
    System Manufacturer Dell Inc.
    System Model OptiPlex 360
    System Type X86-based PC
    Processor x86 Family 6 Model 23 Stepping 6 GenuineIntel ~2493 Mhz
    BIOS Version/Date Dell Inc. A01, 28/11/2008
    SMBIOS Version 2.5
    Windows Directory C:\WINDOWS
    System Directory C:\WINDOWS\system32
    Boot Device \Device\HarddiskVolume2
    Locale United States
    Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)"
    User Name MET-SEAMLTD\Philip
    Time Zone GMT Daylight Time
    Total Physical Memory 2,048.00 MB
    Available Physical Memory 1.09 GB
    Total Virtual Memory 2.00 GB
    Available Virtual Memory 1.96 GB
    Page File Space 3.84 GB
    Page File C:\pagefile.sys
    OS Name - Microsoft Windows XP Professional
    Version - 5.1.2600 Service Pack 3 Build 2600
    OS Manufacturer - Microsoft Corporation
    System Name - DG9LV84J
    System Manufacturer - Dell Inc.
    System Model - OptiPlex 360
    System Type - X86-based PC
    Processor - x86 Family 6 Model 23 Stepping 6 GenuineIntel ~2493 Mhz
    BIOS Version/Date - Dell Inc. A01, 28/11/2008
    SMBIOS Version - 2.5
    Windows Directory - C:\WINDOWS
    System Directory - C:\WINDOWS\system32
    Boot Device-  \Device\HarddiskVolume2
    Locale - United States
    Hardware Abstraction Layer - Version = "5.1.2600.5512 (xpsp.080413-2111)"
    User Name - MET-SEAMLTD\Philip
    Time Zone - GMT Daylight Time
    Total Physical Memory - 2,048.00 MB
    Available Physical Memory - 1.09 GB
    Total Virtual Memory - 2.00 GB
    Available Virtual Memory - 1.96 GB
    Page File Space - 3.84 GB
    Page File - C:\pagefile.sys
    Name Intel(R) G33/G31 Express Chipset Family
    PNP Device ID PCI\VEN_8086&DEV_29C2&SUBSYS_02941028&REV_0A\3&172E68DD&0&10
    Adapter Type Intel(R) GMA 3100, Intel Corporation compatible
    Adapter Description Intel(R) G33/G31 Express Chipset Family
    Adapter RAM 384.00 MB (402,653,184 bytes)
    Installed Drivers igxprd32.dll
    Driver Version 6.14.10.4957
    INF File oem7.inf (iBLB0 section)
    Color Planes 1
    Color Table Entries 4294967296
    Resolution 1440 x 900 x 60 hertz
    Bits/Pixel 32
    Memory Address 0xDFE00000-0xDFE7FFFF
    I/O Port 0x0000ECD8-0x0000ECDF
    Memory Address 0xC0000000-0xCFFFFFFF
    Memory Address 0xDFF00000-0xDFFFFFFF
    IRQ Channel IRQ 16
    I/O Port 0x000003B0-0x000003BB
    I/O Port 0x000003C0-0x000003DF
    Memory Address 0xA0000-0xBFFFF
    Driver c:\windows\system32\drivers\igxpmp32.sys (6.14.10.4957, 5.74 MB (6,021,184 bytes), 03/04/2009 03:42)
    PNP Device ID PCI\VEN_8086&DEV_29C3&SUBSYS_02941028&REV_0A\3&172E68DD&0&11
    INF File oem7.inf (iBLB1 section)
    Color Planes Not Available
    Color Table Entries Not Available
    Resolution Not Available
    Bits/Pixel Not Available
    Memory Address 0xDFE80000-0xDFEFFFFF
    Philip Hamilton
    *Pro
    09-06-2010 07:53 AM in reply to: philipmetseam
    Well, your processor is a SSE2 compliant one, your OS is XP SP3 (SP4 is not supported), but I do see that your graphics card is using integrated graphics and not a dedicated card.  These older Intel chipsets are not really suitable (although many have worked in a horrible way).  You might try installing a inexpensive Direct3D compliant card.  Even it is not the end all solution it would be beneficial to the system and Inventor LT.  It would take memory load off your RAM and onto the GPU and RAM of the card.
    Mark Flayler
    *Pro
    09-06-2010 07:55 AM in reply to: Mark_Flayler
    Was this installed from a received disc from Autodesk or was it downloaded?  If it was downloaded from the Autodesk site I would recommend you try and redownload it as some of the files may have become corrupt in the process, especially if AVG was on during the download process.  You can always request a disc as well if you need to.
    Mark Flayler
    *Pro
    09-06-2010 07:59 AM in reply to: Mark_Flayler
    In addtion, the Inventor.exe message originates from duplicat entries in the registry.  Did you ever have Inventor 2011 full version or any 2011 beta of any kind in the machine at any point?  That might have to bel cleaned out as well.
    Also, Inventor LT and Inventor Series or any other advanced varient cannot co-exist on the same machine due to these restrictions of the registry.
    Mark Flayler
