Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Inventor Registry?
- Highlight
- Email to a Friend
Hello Donal,
When i run Inventor this is what happens:
- Windows Message:
Registration of Inventor.exe
Inventor.exe needs to reregister with the operating system and the following programs (Explorer) are running and may prevent registration from successfully completing. Autodesk recommends terminating the offending processes to ensure proper registration. Terminate the processes before continuing with the registration?
AT THIS POINT I CAN SELECT Yes, No or Cancel.
I click on Yes (However i tried clicking on other two options, nothing changed) and i make sure that all programs are closed.
- Windows Error Message:
Autodesk Inventor LT 2001: Inventor.exe – Entry Point Not Found
The procedure entry point GetProcessHandleFromHwnd could not be located in the dynamic library OLEACC.dll.
AT THIS POINT I CAN ONLY SELECT “OK”.
- Windows Message:
Autodesk Inventor LT 2011
Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\DI.dll.
- The Windows Error Message (Point 2) is repeated.
- Windows Message:
Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\DtExt.dll.
- The Windows Error Message is repeated three times.
- Windows Message:
Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\MbUI.dll.
- The Windows Error Message is repeated twice.
- Windows Message:
Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\Nb.dll.
- The Windows Error Message is repeated.
- Windows Message:
Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\DIDwg.dll.
- Windows Message:
Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\DWGExt.dll.
- Windows Message:
- Windows Message:
Cannot load library C:\Program Files\Autodesk\Inventor LT 2011\Bin\Pf.dll.
- Then the Autodesk Inventor Error Report comes up. I have filled this in, but never got a response.
Can you help me? Or inform me who i can contact to solve this?
Philip Hamilton
Philip Hamilton
Estimator and Technical Advisor
Met-Seam Ltd, Silverwood Industrial Estate, Craigavon, Northern Ireland, BT66 6LN
Tel: +44 28 3832 5757 Fax: +44 28 3832 5758
Mobile: 0775 4463 967 e-mail: philip@metseam.com Web: www.metseam.com
This e-mail is only intended for the person(s) to whom it is addressed and may contain confidential information. Unless stated to the contrary, any opinions or comments are personal to the writer and do not represent the official view of the company. If you have received this e-mail in error, please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person. Although this email and attachments are believed to be free of virus, or any other defect which might affect any computer or IT system into which they are received and opened, it is the responsibility of the recipient to ensure that they are virus free and no responsibility is accepted for any loss or damage arising in any way from receipt or use thereof.
Thank you for your co-operation.
Re: Inventor Registry?
- Highlight
- Email to a Friend
philipmetseam wrote:Hello Donal,
Not sure where that came from, but -
...what is your OS?
If Vista or Window 7 did you turn off UAC before install?Try turning off now and reboot. Click yes to the registry message.
If no change,
try a Repair Install
if still no change
try a clean uninstall/reinstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
teID=123112&id=14893355&linkID=9242018
Autodesk Inventor Certified Professional
Inventor Professional 2012 Edu 32-bit
Still waiting for -Draft option on any Rib feature. -Properties Painter.
- Highlight
- Email to a Friend
Thank you.
I have already tried all this.
The OS is XP.
Any other suggestions?
Thanks again.
Philip Hamilton
- Highlight
- Email to a Friend
What antivirus do you have? Was it off during the install?
Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog: http://blogs.rand.com/manufacturing/
- Highlight
- Email to a Friend
AVG and it was off during the install
Philip Hamilton
- Highlight
- Email to a Friend
Since this is an XP machine, do you have a SSE2 complient processor? I used to see a problem based on this on older Intel or AMD processor structures. How about you list all your system specs here to rule out most of these hardware issues.
Type in MSINFO32 in your run box and report on those results.
Report on the main screen and the Components>Disply information.
- Highlight
- Email to a Friend
OS Name - Microsoft Windows XP Professional
Version - 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer - Microsoft Corporation
System Name - DG9LV84J
System Manufacturer - Dell Inc.
System Model - OptiPlex 360
System Type - X86-based PC
Processor - x86 Family 6 Model 23 Stepping 6 GenuineIntel ~2493 Mhz
BIOS Version/Date - Dell Inc. A01, 28/11/2008
SMBIOS Version - 2.5
Windows Directory - C:\WINDOWS
System Directory - C:\WINDOWS\system32
Boot Device- \Device\HarddiskVolume2
Locale - United States
Hardware Abstraction Layer - Version = "5.1.2600.5512 (xpsp.080413-2111)"
User Name - MET-SEAMLTD\Philip
Time Zone - GMT Daylight Time
Total Physical Memory - 2,048.00 MB
Available Physical Memory - 1.09 GB
Total Virtual Memory - 2.00 GB
Available Virtual Memory - 1.96 GB
Page File Space - 3.84 GB
Page File - C:\pagefile.sys
Name Intel(R) G33/G31 Express Chipset Family
- Highlight
- Email to a Friend
Well, your processor is a SSE2 compliant one, your OS is XP SP3 (SP4 is not supported), but I do see that your graphics card is using integrated graphics and not a dedicated card. These older Intel chipsets are not really suitable (although many have worked in a horrible way). You might try installing a inexpensive Direct3D compliant card. Even it is not the end all solution it would be beneficial to the system and Inventor LT. It would take memory load off your RAM and onto the GPU and RAM of the card.
- Highlight
- Email to a Friend
Was this installed from a received disc from Autodesk or was it downloaded? If it was downloaded from the Autodesk site I would recommend you try and redownload it as some of the files may have become corrupt in the process, especially if AVG was on during the download process. You can always request a disc as well if you need to.
- Highlight
- Email to a Friend
In addtion, the Inventor.exe message originates from duplicat entries in the registry. Did you ever have Inventor 2011 full version or any 2011 beta of any kind in the machine at any point? That might have to bel cleaned out as well.
Also, Inventor LT and Inventor Series or any other advanced varient cannot co-exist on the same machine due to these restrictions of the registry.
