• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    cjj
    Active Member
    cjj
    Accepted Solution
    Inventor Professional 2009 Dimension Edit Box Greyed Out
    630 Views, 5 Replies
    09-10-2010 09:50 AM
    I am endeavouring to make the slow transition from 13 years of MDT over to Inventor.
    When I try to edit a driven dimension the edit box is greyed out.
    Pic attached of problem.
    Can anyone help please?
    I have spent the last 3 hours searching these forums and generally online to no avail.
    Thank you.
    CJJ
    **Master
    Re: Inventor Professional 2009 Dimension Edit Box Greyed Out
    09-10-2010 10:15 AM in reply to: cjj
    your dim is a driven dimension, meaning that it is determined by the geometery, rather than driving the geometry. Depending on the situation you can may be able to switch the dim to driving, using the button to toggle it. Ii can't recall where that button is in 2009 though.
    **Master
    09-10-2010 10:32 AM in reply to: BMiller63
    see attached, it shows the location of the driven dim toggle.
    in the series of pictures, the one leg of the triangle is switched from a driving dim to a driven dim, then the angle dim is switched to become drving.
    one thing to note about the toggle is that it can be toggled on, resulting in all of yur dims being created as drven dims. if that happens just toggle it off.
    hope this helps.
    cjj
    Active Member
    cjj
    09-10-2010 10:48 AM in reply to: BMiller63
    That is Great !
    Thank you.
    I would have been struggling forever without your kind assistance.
    Thank you once again.
    CJJ
    **Master
    09-10-2010 11:38 AM in reply to: cjj
    you're very welcome.
    you might get a copy of Introducing Autodesk Inventor 2009 and Autodesk Inventor LT 2009
    http://www.amazon.com/Introducing-Autodesk-Inventor-2009-LT/dp/0470375523/ref=ntt_at_ep_dpi_2
    it's a very good intro to Inventor book
    cjj
    Active Member
    cjj
    09-10-2010 12:02 PM in reply to: BMiller63
    I managed to resolve the dimensional problem with your kind help and have ordered a copy of the book you recommended.
    Christopher
