• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Cadmanto
    Inventor Feature works?
    331 Views, 24 Replies
    03-22-2012 01:48 PM
    For those of you that know Solidworks, they had a feature that could create features from dumb solids called featureworks.  Does Inventor have anything similar?
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Please use plain text.
    jtylerbc
    Re: Inventor Feature works?
    03-22-2012 01:51 PM in reply to: Cadmanto
    Yes, but it's an add-in, so you'll have to download and install it first.
    http://labs.autodesk.com/utilities/feature_recognition/
    John Tyler
    Inventor 2013
    Windows 7 64 Bit
    Valued Mentor
    CelticDesignServices
    03-22-2012 02:02 PM in reply to: jtylerbc
    Yeah, I really wish this was finally part of basic Inventor by now.
    Labs has had this feature for a few realeses now and I use it all the time when dealing with vendor files.
    Jim
    Celtic Design Services, LLC
    Inventor/AutoCAD/Vault WorkGroups
    Always for hire - celticdesign01ATyahooDOTcom
    http://www.linkedin.com/pub/celticdesignservices-llc/51/610/398/
    Please use the Accept as Solution and Give Kudos functions as appropriate to further enhance the value of these forums.
    Go raibh maith agat (in other words...Thank you!)
    Cadmanto
    03-22-2012 03:05 PM in reply to: Cadmanto
    Thanks.  I will try this when I get back to work.
    We are using profressional so I am miffed that this ins't included as well.
    Have you used it and if so what are your thoughts?
    Best Regards,
    Scott McFadden
    Cadmanto
    03-22-2012 03:07 PM in reply to: CelticDesignServices
    Jim,
    Me too!!!
    I used it periodically when I was using Solidworks.  It was good for simple machined type parts.
    Forget it on the ergonomic swept type parts.
    Best Regards,
    Scott McFadden
    jtylerbc
    03-22-2012 03:27 PM in reply to: Cadmanto
    My thoughts are that I've never needed it badly enough to be worth the trouble of trying to get IT to install it for me . . .
    John Tyler
    Inventor 2013
    Windows 7 64 Bit
    03-22-2012 06:17 PM in reply to: Cadmanto
    Identical to FeatureWorks.
    I never use Automatic in Inventor or SolidWorks.
    Use in manual mode and recognize only those features that will actually be edited.
    You can multiple select then right click to combine circular or rectangular patterns.
    Cadmanto
    03-23-2012 11:01 AM in reply to: JDMather
    Thanks JD.
    My question now is I have downloaded it and when I go to the addins list I am not seeing it in the list.
    How do I get it into my Inventor session?
    I ahve already closed out of inventor and restarted that thinking that would work...Not!!!
    Best Regards,
    Scott McFadden
    RayFeiler
    03-23-2012 11:07 AM in reply to: Cadmanto
    I guess no one likes Fusion?
    Product Design Suite Ultimate 2014 64-Bit Update 1
    Sometimes you just need a good old reboot.
    03-23-2012 11:08 AM in reply to: Cadmanto
    You must install with anti-virus and UAC turned off.
    I had the same problem on of my machines till I turned UAC off.
