• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    hoaglin14
    Inventor Drawings to AutoCAD
    899 Views, 16 Replies
    08-09-2011 07:24 AM
    I have been trying to export inventor drawings to dwg files so they can be opened in AutoCAD and be edited.  However when they are opened in AutoCAD, the views cannot be exploded for our needs.  Any help?
    Please use plain text.
    Valued Mentor
    jclaidler
    Re: Inventor Drawings to AutoCAD
    08-09-2011 07:27 AM in reply to: hoaglin14
    Are you doing a 'Save Copy As'??
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
    Valued Mentor
    coreyparks
    08-09-2011 07:30 AM in reply to: hoaglin14
    Do a "Save copy as" and select to save as an AutoCAD DWG not an Inventor DWG.
    Please mark this response "Accept as solution" if it answers your question.
    Corey Parks
    IV2012 Factory Design Suite Ultimate 64bit
    Includes: Inventor Professional, AutoCAD Architecture & Navisworks Manage
    Windows 7 64 bit- Synergis Adept document management software
    16gb RAM --- Nvidia Quadro 4000 2gb
    hoaglin14
    08-09-2011 08:51 AM in reply to: coreyparks
    Yes, I have tried to save copy as AutoCAD dwg but for some reason when I open it, it will not let me explode anything
    Valued Mentor
    coreyparks
    08-09-2011 09:03 AM in reply to: hoaglin14
    Sorry can't help at this point.  If your exporting as the proper DWG type as you said, it has always worked fine for me.  I have only seen the issue when saved as an Inventor DWG, then it can only be viewed in AutoCAD and not modified.
    Corey Parks
    hoaglin14
    08-09-2011 10:49 AM in reply to: coreyparks
    The only way I can get it to work is if I save copy as a dxf file, then open it in AutoCAD, then save as a dwg file. After all that I can finally edit the dwg file in AutoCAD but that seems like too long a process
    Valued Mentor
    coreyparks
    08-09-2011 11:06 AM in reply to: hoaglin14
    Can you post the DWG you are having a problem with?  Or make one quick that has the issue so we can take a look?  Post all of the files involved if you can.
    Corey Parks
    Distinguished Contributor
    08-09-2011 11:20 AM in reply to: coreyparks
    If you use the option to move the views in Inventor to model space they are then contained in the dwg file as blocks (cant be seen on the model space in ACAD).  You can then use the design palette (I think it's called that) to select the block and place it.  You can then explode and edit the block.
    A bit of a work around but it is possible.
    Cheers,
    Guy
    AutoCADM 2011 SP2
    XP 32-Bit SP3
    hoaglin14
    08-09-2011 11:33 AM in reply to: coreyparks
    I have attached both the inventor file and the AutoCAD file that will not let me explode the views
    Valued Mentor
    coreyparks
    08-09-2011 12:59 PM in reply to: hoaglin14
    I believe I see the problem you are having.  You can't explode it and every time you select a view it selects everything in the view, correct?  During the export to AutoCAD Inventor made all the views using groups in AutoCAD.  You can toggles the selectability of these group with ctrl+H.  This changes the pickstyle variable between 1 and 0.  Give it a go, it should fix the problem.
    Corey Parks
