• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    blair
    Re: Inventor Crashes when loading any file, or closing welcoming center
    01-19-2013 09:25 PM in reply to: terpsurfer
    Not really sure why you are having the installation problems that you are. Along with JD's recommendations, make sure that you have Administrative Privildges as well as having the UAC turned off (slider set to lowest setting) and your A/Virus software disabled just for the Installation. Some A/V software will stop certain edits to the Windows Registry. Make sure your .NET is at 4.0
    I would make sure that you are current on all Windows SP's and hotfixes for your O/S and current graphics card drivers.
    I would use the Autodesk Clean Un-Install to remove all traces of the old install prior to trying to re-install the software.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14893355&linkID=9242018
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Please use plain text.
    *Pro
    sbixler
    01-20-2013 04:43 PM in reply to: blair
    Stuff like this can result from a corruption somewhere in your user profile.  Try starting Inventor from a different login (with power user privileges or better).  If this works, then delete every bit of anything related to Inventor from your profile and try again.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Active Member
    01-20-2013 08:40 PM in reply to: sbixler
    .net Framework is @ 4
    uac has been turned off
    vista sp1 & 2 have been installed
    I'm currently working on the graphics drivers and should have it finished soon. I'm able to run revit 2012 so i'm not sure why its a problem, anyways..
    I will turn off my a/v during the install and I hope it works! Thanks for all the help!
    Active Member
    01-21-2013 02:31 PM in reply to: terpsurfer
    Same exact problem with ALL of these issues addressed. I'm fed up and pissed. Can someone pless point me in the direction of a customer support rep?
    DarrenP
    01-21-2013 02:34 PM in reply to: terpsurfer
    all support is through the reseller channel
    http://usa.autodesk.com/adsk/servlet/ps/searchform?id=1088201&siteID=123112
    FYI vista is not a supported OS anymore with any 2013 products
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18424371
    it also could be your computer can't handle inventor 2013
    Active Member
    01-21-2013 05:15 PM in reply to: DarrenP
    Alright, so what If I were to try inventor 2012?
    Active Member
    01-21-2013 06:29 PM in reply to: terpsurfer
    Attempted to install the 2012 version and to my surprise I found this!
    I'm now going to attempt to install AutoCAD_Architecture
    blair
    01-21-2013 11:03 PM in reply to: blair
    Check in the primary folder for the installation (where the setup.exe file resides), there should be a "readme" file.
    Win7-64
    01-23-2013 07:51 AM in reply to: terpsurfer
    A 6 or 7 year old computer?
    When was the last time the HDD was reformatted and OS re-installed (a lot of garbage can build up over several years).
    I was running an old computer (about the same specs as yours) and it was getting slower and slower and I had trouble installing Autodesk Simulation.  New install of the original OS and it worked better than it had in years.
    Where are you getting the 2012 software (student download?)?
    As noted above this is a free peer-to-peer user support group, not the Autodesk support.
    Support is through your VAR (Value Added Reseller).
    There is also peer support here and often Autodesk Employees chime in, but provide all information
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    Inventor Professional 2014 Edu 64-bit
