• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Johnnyjack777
    Inventor Crashes on Simple Spline Extrude?
    233 Views, 4 Replies
    10-20-2012 08:27 PM
    Curious... what the heck?
    Crashes on a simple extrusion... VERY basic spline...
    (When I click extrude... I doubt it's even a complete closed shape yet)
    any thoughts?
    Please use plain text.
    Distinguished Contributor wh
    wh
    Betreff: Inventor Crashes on Simple Spline Extrude?
    10-20-2012 11:34 PM in reply to: Johnnyjack777
    Set additional lines to construction lines, and it's ok.
    Walter
    *Expert Elite*
    Re: Inventor Crashes on Simple Spline Extrude?
    10-21-2012 07:41 AM in reply to: Johnnyjack777
    Just took a look back through your previous posts here.
    I don't see any improvement in your sketching techniques.
    I recommed you read this document.
    http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
    by this point you have probably developed bad habits that will be hard to break.
    Find the Origin Center Point and use it.
    Use Construction lines where appropriate (this was pointed out to you on an earlier problem).
    Employee
    10-21-2012 08:04 PM in reply to: Johnnyjack777
    When using the dataset to extrude it, there is no crash seen. Maybe there are some key steps I missed. So could make more comments about the steps or workflow?
    River Cai
    Quality Assurance Team
    Autodesk, Inc.
    *Expert Elite*
    10-22-2012 05:12 AM in reply to: Yijiang.Cai
    Note that iProperties indicates the file is r2010 apparently with no Service Packs installed.
