• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    New Member
    Inventor 6 Getting Started Workbook
    48 Views, 2 Replies
    11-13-2002 01:31 AM
    I can not find the correct files for Chapter 6 of this workbook. I need the correct file IV6_E06_05.IAM the CD that came with Inventor has the wrong file.
    Anyone else having this problem?
    Please use plain text.
    *Autodesk\
    Re: Inventor 6 Getting Started Workbook
    11-14-2002 10:05 PM in reply to: Grest
    Hello "Grest",
    After seeing this posting, I put on my "Columbo"
    overcoat and investigated this exercise and the associated assembly and part
    files with a more technical eye.  My findings were that the exercise
    and exercise files appear to be working as
    described.  May I suggest
     the
    following:
    1) Make sure you follow the steps exactly as
    described.  Immediately after creating a new presentation
    face=Arial size=2> file, and then using the Create View tool to open the
    assembly
    file, you are asked to select
    the
    "Internal Components" design view.
    This design view turns the visibility of the two outer components (cylinder and
    cylinder head) off, leaving the internal components visible.  If you do not
    use
    this design view, the assembly may
    appear as the wrong file.
    2) Make sure the active project is:
    Getting_Started_Exercises as described in the Introduction
    section of the Getting Started Exercises. If this is not the active
    project, you
    may not have access to the
    "Internal Components" design view after selecting the assembly
    file.
    Cheers,
    RodneyK
    Mechanical Training Development and QA
    Manager
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I
    New Member
    Re:
    11-15-2002 05:22 AM in reply to: Grest
    I'll try it again.
