• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Inventor 5 wont open!!!
    67 Views, 3 Replies
    12-02-2006 11:07 AM
    So i recently tried to load Inventor 5 onto my home computer. The installation went fine, but now the welcome image opens (a spaceship) for a couple seconds, disappears, and then nothing else happens. any help would be great!
    Please use plain text.
    *Duncan Anderson
    Re: Inventor 5 wont open!!!
    12-04-2006 04:31 AM in reply to: mattman_83
    It's a very deep sub-mersible
    Inv should go to the Activation/Registration screen after the initial splash screen.
    Did you disable your anti-virus when installing ?
    Do you have Flash8(a) installed - remove using the utility from
    http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_14157
    And then install Flash9 http://www.adobe.com/go/getflashplayer
    Duncan
    "Humour ... is one man shouting gibberish in the face of authority, and proving by
    fabricated insanity that nothing could be as mad as what passes for ordinary
    living."
    (Terence 'Spike' Milligan K.B.E., 1918-2002)
    www.autodesk.co.uk/inventorjobs
    wrote in message news:5412885@discussion.autodesk.com...
    *Joe Howard
    12-04-2006 05:09 AM in reply to: mattman_83
    Do you have Excell on your home machine? it is required for inventor and if
    just installed excell you must open excell at least once to activate it.
    be great!
    *Gary R Smith \(Autodesk\)
    12-04-2006 06:45 AM in reply to: mattman_83
    You might also make sure that your home machine has a graphics card/drivers
    that supported INV5
