• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Inventor - 3D modelling without sketching? Possible?
    144 Views, 4 Replies
    05-04-2012 10:45 AM
    Is there a way to create 3d objects in Inventor without having to 'sketch' in 2d first? Such as draw a vertical 3Dcylinder simply by defining its radius and height, without extruding?
    Please use plain text.
    bryanthomas
    Re: Inventor - 3D modelling without sketching? Possible?
    05-04-2012 10:59 AM in reply to: i_am_fail
    Inventor 2013 does have a primitives feature that will generate a cylinder for you based off inputs. However essentially it is still making a 2D sketch and extruding it. Inventor is a history based 3D CAD program. However I believe Inventor fusion or Alias would be able to do want you want without giving you that sketch-extrusion structure. Just a thought.
    Active Member
    05-04-2012 11:16 AM in reply to: bryanthomas
    is inventor 2013 even out yet?
    05-04-2012 11:41 AM in reply to: i_am_fail
    Yes..been out for afew weeks now.. and yes it does have "primative" shapes now..
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Valued Mentor
    CelticDesignServices
    05-04-2012 01:45 PM in reply to: mcgyvr
    Actually these "primatives" have been in Inventor's Content Center for a few releases now.
    I want to say since 2010???
    Jim
    Celtic Design Services, LLC
    Inventor/AutoCAD/Vault WorkGroups
    Always for hire - celticdesign01ATyahooDOTcom
    http://www.linkedin.com/pub/celticdesignservices-llc/51/610/398/
    Please use the Accept as Solution and Give Kudos functions as appropriate to further enhance the value of these forums.
    Go raibh maith agat (in other words...Thank you!)
