• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    blair
    Re: Inventor 2013 slow with saving and updating
    11-20-2012 08:59 AM in reply to: markben
    That's it! Not a really big model. I thought it was something like the following:
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Please use plain text.
    blair
    11-20-2012 09:03 AM in reply to: blair
    Looks like you are using note-books. These have poor hard-drive speed. Run the Performanceand Information Tools from the Windows Control Panel. What sort of Primary hard disk numbers do you get. Almost sounds like you have Disk I/O problems on your server if you see the same times when compared to a laptop with the content local.
    Win7-64
    11-20-2012 09:13 AM in reply to: shawn.payne
    Working with that assembly should be fairly trivial.
    Is there any chance you can post a dataset that exhibits this behavior?
    Has you VAR tried to find the source of the problem.
    You definately should not be seeing this problem and it is costing your company time (money).
    Active Member
    11-20-2012 09:46 AM in reply to: JDMather
    What type of dataset from inventor do you need?
    blair
    11-20-2012 10:04 AM in reply to: blair
    A complete Pack-and-Go for the assembly. This will include all files and drawings.
    Also if you can expand your IPJ project file showing the directory layout as well as a you network lay-out (mapped directories (screen capture for both).
    Win7-64
    Active Member
    11-20-2012 10:07 AM in reply to: blair
    I will have to get an ok from my supervisor for the pack and go. Ill let you know when they get back to me. In the meantime thank you for your help so far.
    11-20-2012 10:57 AM in reply to: shawn.payne
    Find an assembly/drawing that isn't proprietary but exhibits the behavior.  Explain to your supervisor that this is costing the company money and there is free help at hand to solve the problem.
    If you already have all the files in a single folder for a project that exhibits this behavior then right click on the folder and select Send to Compressed (Zipped) Folder and attach the resulting *.zip file here.
    If not, open the idw and do the Save As Pack and Go (set to Skip the stuff we don't need).
    Extract your zip yourself to make sure it still exhibits the behavior.
    If you can't get the OK to post on a public forum, my guess is someone from Autodesk will be along to offer a secure check of the data.
    Active Member
    11-20-2012 02:01 PM in reply to: JDMather
    The file is too large for the forum. I have emailed it to you.
    New Member
    04-10-2013 08:15 AM in reply to: blair
    I am having the same issues!  I am working with even smaller files that the skid example that started this forum (see picture).  I thought it was a network issue also, so I loaded my project onto my computer's hard drive.  Things are still really slow.  No change.  In addition to slow saves and loads, the whole program seems slow.  It takes forever to create views on drawings from a 3D model.
    My computer:
    Dell Latitude
    2.67 i7 Processor
    8 GB RAM
    512 GB SSD
    512 GB Nvidia Graphics Card
    Windows 7 Pro (64 bit)
    We upgraded from Inventor 2009 and never had this trouble before.  It seems like the program has trouble regardless of file size.  It is like it gets lost with itself and just times out more than being overburdened.  I never even come close to the processor's limits, RAM usage, graphics card usage, etc. when watching the Windows system monitor.  When I go back to Inventor 2009, I get quick loads, processes, saves, etc.
    blair
    04-10-2013 08:46 AM in reply to: shawn.payne
    Run the "Performance Information and Tools" from the control panel and post the results.
    Win7-64
