• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: Inventor 2013 "half section view" mode
    01-09-2013 11:03 AM in reply to: vheller
    vheller wrote:
    Please note that all information in this file is confidential.
    Then I strongly suggest you not post where everyone can get it.
    Please use plain text.
    Active Member
    vheller
    01-09-2013 11:39 AM in reply to: JDMather
    Any other way to grant you access to this file to investigate an issue?
    Valued Mentor
    01-09-2013 11:49 AM in reply to: vheller
    So, let me get this straight, you are trying to create a section view on a drawing?
    I would start by trying to make the section view a little bit to one side of where you are getting the problem. Then try far enough that some parts would be excluded if it's an assembly (in a part, I guess, you would want to get past some features, like if there's an extrusion or a loft or something). If you can get a section to work then you look at what is where it didn't work.
    Valued Mentor
    Re: Inventor 2013 "half section view" modeI put an assembly in another assembly
    01-09-2013 11:52 AM in reply to: vheller
    Active Member
    vheller
    01-09-2013 12:18 PM in reply to: dan_inv09
    There is only one drawing attached - GA-002.dwg, I guess... Yes, I'm trying to make section view in that one to show both sides of the skid from inside center line.
    Active Member
    vheller
    01-10-2013 11:29 AM in reply to: dan_inv09
    Doesn't really work... I can't create any section view from this assembly, even if I hide some stuff in view.
    Active Contributor
    01-15-2013 05:44 AM in reply to: BrianSchultz3877
    As always when Autodesk makes "improvements" to the user-interface we get some new and (sometimes) interesting features, at the expence of some or other of the useful, or at least workable, features which we have gotten acustomed to.
    It surely must be a mistake that when wanting to create a "Half Section View" in an assembly, we are not able to "sign out" this action by just using the enter button.
    What is the rationale, what on earth is the improvement over previous versions of the wonderful tool called "Inventor", that after selecting: "View" -> "Half Section View", then clicking on a plane / part surface and consequently dragging the offset to "whatever", adjusting the offset by typing in a number in the dialog-field, and then hitting "Enter" to confirm: The whole dialog-box disappears, and then you cannot just hit "Enter" to confirm that you in fact do want to create such a "Half Section View"?
    No, no - you then, off course, have to right-click (which miraculously makes the dialogue re-appear) for the final click on the "OK" button.
    Quelle Magnificence, Quelle Luxe!
    NOT!
    Active Member
    vheller
    01-15-2013 08:41 AM in reply to: dan_inv09
    Hello.
    It does work. The wierd thing is instance of same subassembly caused this problem.
    Thank you.
