• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    zdhrichard
    Accepted Solution
    Inventor 2013 open *.prt (Pro/E file) issue
    1221 Views, 6 Replies
    10-09-2012 11:40 AM
    Does any body know why Inventor 2013 cannot open an *.prt (Pro/E) file as attached?
    I can open it in Inventor 2009, but when I tried to open it in Inventor 2013, it said "Unable to convert Pro/ENGINEER or Creo Parametric file to Inventor file."
    Richard Z.
    Autodesk Inventor Professional 2013 (64 Bit) SP1.1
    Windows 7 Professional Service Pack 1
    Intel(R) Xeon(R) CPU E5645
    12.0 GB Memory
    Please use plain text.
    Distinguished Contributor
    Re: Inventor 2013 open *.prt (Pro/E file) issue
    10-09-2012 01:23 PM in reply to: zdhrichard
    Opened as a Solidworks file in Inventor 2012. File is blank.
    Distinguished Contributor wh
    wh
    10-09-2012 01:32 PM in reply to: R.Corriveau
    Opens well  as Pro/E-PRT in 2010, too.
    2011 and newer versions refuse.
    Comments from ADesk are welcome.
    Walter
    *Expert Elite*
    10-09-2012 01:43 PM in reply to: zdhrichard
    First thing I noticed is that there was a space in the filename. Pro/E doesn't allow spaces in filenames?
    After removing the space - I was able to open the file in Creo 2.0
    Edit - I was able to open the file in Inventor 2013.
    Inventor Professional 2014 Edu 64-bit
    wh
    10-09-2012 01:50 PM in reply to: JDMather
    Interesting; Jeffrey.
    Renaming to RPEE_LEN.prt did it here, too.
    Distinguished Mentor
    10-09-2012 01:51 PM in reply to: JDMather
    Opens here too, after taking the space out of the file name.Inventor 2013
    Dell Precision T3500
    Windows 7 64-bit
    12GB RAM
    dual NVidia Quadro 2000
    Driver 297.03
    John Retzlaff
    Valued Contributor
    zdhrichard
    10-09-2012 01:57 PM in reply to: john.retzlaff
    Thanks lot, Guys!
    After removing space, it works.
    Inventor 2009 accept space, 2013 does not.
    Richard Z.
    12.0 GB Memory
