• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Inventor 2013 on Parallels on a Mac Pro.
    906 Views, 9 Replies
    05-03-2012 01:32 PM
    All,
    We're desparate to find information on the viability of running Inventor 2013 (or even 2011 or 2012) under Parallels on a Mac Pro. The Mac FAQ hasn't been updated since 2008 as far as we can tell.
    Here's where we're at:
    Candidate Hardware
    • Mac Pro (current gen) with 2 x 2.4GHz quad-core Xeon running
    • Mac OS 10.6.8,
    • 12Gb RAM
    • 2 x 2Tb hard disks, configured as RAID 1 with Mac OS, Parallels 7, Windows 7.
    • ATI Radeon HD 5770 1Gb
    Questions
    1. Assuming models typically with < 5,000 parts, Is this beefy enough hardware? Enough RAM? Big enough graphics card for two monitors?
    2. Any recommendations on graphics settings in Parallels / Windows in order to get good performance? Turn off Aqua & use DirectX?
    3. Can we get away with the RAID 1 for fault tolerance? Can you suggest a better strategy (maybe SSD in bay 1 with Mac OS 10.6.8, Parallels, Windows, then RAID 1 storage volume in bays 2 & 3)?
    4. How big a performance hit are we taking by running this way instead of Bootcamp?
    5. We would like to have the files saved into the Mac OS file system as opposed to filing them on the Windows VM. This allows us to make automated backups of just the files as opposed to the entire VM? In reading the FAQ, it appears that this will require us to format the VM as FAT, not NTFS, which limits partition sizes to 32Gb. Are we crazy to entertain this idea? Is this even possible? Is there a way to use NTFS and use the Mac OS for file storage?
    6. Our backup strategy will involve making a copy of the pristine VM once Inventor is installed, allowing "instant" restore of the VM if something hits the guardrail. Does this seem like a good idea or are we nuts?
    We would give a digit to speak to someone with real-word experience running this (or a similar) setup. Any and all input is welcome.
    Many thanks.
    Please use plain text.
    Distinguished Contributor
    Re: Inventor 2013 on Parallels on a Mac Pro.
    05-03-2012 04:36 PM in reply to: jbobdobbs
    We run on Macs here - but we use Bootcamp. I have tried parallels briefly in the past - and it used to have trouble with the video requirements of Inventor.
    Mechanix Design Solutions inc.
    Active Contributor
    donovandigital
    05-03-2012 07:32 PM in reply to: jbobdobbs
    No experience with this specifically but your backup strategy is right on target. Only make sure you go sector-by-secrtor on the physical device rather than partition or anything like that.
    Might I ask, why must you do this? PCs are pretty cheap nowadays.
    Member
    05-04-2012 04:18 AM in reply to: donovandigital
    "Might I ask, why must you do this? PCs are pretty cheap nowadays."
    We want an integrated environment that allows the operator to use Mac-only tools (Daylite, for example). We would prefer to move away from the risks and complexity of the Windows platform towards the simplicity and depth of the Mac. If we're running Bootcamp, we may as well be running a Dell.
    We double-checked with our operators and they're saying that the object count in their work is typically < 1000 pieces in a model. We're hoping that this makes the Parallels solution more viable.
    Is Inventor Fusion a Mac-native, direct replacement for Inventor 2012 / 2013? If so, perhaps this is the way we should go, although building a business on software that is, at least by my understanding, still in heavy beta, seems a fairly significant risk.
    Again, any and all input is welcome.
    Active Contributor
    donovandigital
    05-04-2012 02:46 PM in reply to: jbobdobbs
    Proposed strategy with no practical implementation advice, real or implied (r)(tm)
    Create VMs on a central server, then access them remotely from Macs. No idea whatsoever if you have enough power/money to do this, or even if its viable for the size of your models, but I recall seeing remote desktop solutions for pc hosts on mac worksatations (cannot remember any names atm, but surely doable, as OS<whatever> is essentially freebsd (*nix).
    Again, no idea alas if this is viable, but I would at least look into it.
    Member
    05-05-2012 06:29 AM in reply to: jbobdobbs
    Good suggestion, but not something we can pull off - these users are local and isolated.
    We've got a more accurate object count now; it's closer to 1,000 max.
    Perhaps Inventor Fusion Mac is the way to go?
    Valued Mentor
    05-06-2012 07:33 AM in reply to: jbobdobbs
    "Is Inventor Fusion a Mac-native, direct replacement for Inventor 2012 / 2013? If so, perhaps this is the way we should go, although building a business on software that is, at least by my understanding, still in heavy beta, seems a fairly significant risk."
    Inventor Fusion is a free download from the Labs website and is only for editing dumb solids (imported part files), it does not handle assemblies or drawings and is in no way a replacement for Inventor.
    Regards
    Martin
    PDSU 2014 RTM
    Windows 7 64bit, Office 2007 Pro
    Intel i7 980x, 24 Gb DDR3 RAM
    Geforce 580GTX Graphics (Diver 310.70)
    256GB SSD OS, 80GB SSD working folder
    Space Pilot
    Member
    05-07-2012 08:17 AM in reply to: Martin_Goodland
    Martin,
    Thanks for the clarfication. We'll stop holding our breath, hoping that Fusion would fill the bill.
    Any other data points from Mac users out there?
    Active Contributor
    donovandigital
    05-07-2012 09:19 PM in reply to: jbobdobbs
    Sorry - local and isolated as in they have no internet connection whatsoever?
    From what I've seen of Inventor's use pf resources, a VPN over a cable modem may well be viable. I would at the very least do stress tests to evaluate.
    Member
    05-08-2012 11:18 PM in reply to: jbobdobbs
    "Sorry - local and isolated as in they have no internet connection whatsoever?"
    Local and isolated, but they've got at least 2Mb/512K up.
    "From what I've seen of Inventor's use pf resources, a VPN over a cable modem may well be viable. I would at the very least do stress tests to evaluate."
    Thanks. Appreciate the guidance.
