• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Inventor 2013 - negative material mass to calculate buoyancy
    214 Views, 3 Replies
    11-20-2012 01:00 AM
    I have a customer who uses negative material mass in Inventor to calculate buoyancy for submerged constructions. After upgrading to 2013, we have a problem: Inventor 2013 does not accept negative material mass :smileysad:
    Any suggestions?
    Please use plain text.
    Product Support
    Daniela_Koloszko
    Re: Inventor 2013 - negative material mass to calculate buoyancy
    11-27-2012 12:19 AM in reply to: hans.martin.haga
    Please see this post:
    http://forums.autodesk.com/t5/Autodesk-Inventor/Negative-mass-calculation-in-Inventor-2013/m-p/37088...
    Daniela Koloszko
    Product Support Specialist
    Autodesk Product Support
    MFG
    Autodesk, Inc.
    11-27-2012 12:38 AM in reply to: Daniela_Koloszko
    The negative density is set using the material properties.
    Product Support
    Daniela_Koloszko
    11-28-2012 05:13 AM in reply to: hans.martin.haga
    The current Inventor 2013 behavior is correct. Inventor uses Protein Library from Inventor 2013 and it doesn’t accept a negative density. That’s why negative density doesn’t work.
    As for workaround, you can "Disable" protein library temporarily. You can do it in the following way:
    • Rename the folder name of “C:\Users\Public\Documents\Autodesk\Inventor 2013\Design Data\Materials”
    • Rename the folder name of “C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2013”
    If you need to have a “negative mass”, you can also override the mass with negative value for your calculation in this case. This is possble both via UI (iproperties dialog box) and API(MassProperties.Mass).
    Daniela Koloszko
    MFG
    Autodesk, Inc.
