• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Inventor 2013 Service Packs
    317 Views, 6 Replies
    10-31-2012 06:45 AM
    Greetings All,
    Can anyone tell me how I can find ot what SP is installed for Inventor 2013?  Also, what is the latest SP for Inv2013 and is it stable for me to install the latest SP's?
    Does the latest SP include all the minor patches and updates that are ot there in separate files?
    Thanks in advance! :-)
    DJD
    P.S. It's been some time since using Inventor of any release, but learning Inventor 2013 is like starting from scratch.  (I blame senility)
    Please use plain text.
    Distinguished Mentor
    Re: Inventor 2013 Service Packs
    10-31-2012 07:12 AM in reply to: sw_convert
    Under the help icon, pick about Autodesk Inventor.
    John Retzlaff
    Active Contributor
    10-31-2012 07:21 AM in reply to: john.retzlaff
    If a SP was installed on this version of Inventor..... would it show in the "about" window?  Or is the SP represented by the Build number?
    I remember from previous versions of Inventor (unless I'm just THAT senile) the "about" window would display the SP version, if it was installed.  This window as you can see from the attachment doesn't show an SP # per se, just a build number.
    Basically, I'm trying to understand if the IT guy installed the SP or not.  He tells me he has, but I'm into a few buggy issues with Inventor 2013.  Doubtless, operator error, but I'd like to at least know that Inventor is up to date from a functionality stand point.
    Edited by
    Discussion_Admin
    10-31-2012 07:32 AM in reply to: sw_convert
    John Retzlaff
    Active Contributor
    10-31-2012 07:51 AM in reply to: john.retzlaff
    Perfect...... thanks! :-)
    Hmmm, I remember your ID from when I posted here way back around 2008'ish or so.
    10-31-2012 09:59 AM in reply to: sw_convert
    You should not post personal serial number on a public forum.
    Active Contributor
    10-31-2012 10:04 AM in reply to: JDMather
    Acknowledged ... on both accounts!
