• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Inventor 2013 Save .idw Copy As DWG problem with nuts
    316 Views, 3 Replies
    11-20-2012 07:01 AM
    Saving .idw As AutoCad drawing converts chamfers on nuts to some strange polyline. See picture.
    Seems like it does not affect bolts. Not all nuts. Nor all projections either but one specific projection.
    I did try Acad 2004 ---2013 versions. Different templates, .ini files all for NO joy.
    Enclosed test .idw and conversion to dwg result.
    Bug?
    Inventor 2013 SP1.1
    Windows 7, 64 bits
    RAM 8GB
    Core TM2 Duo CPU 2,99 Gz
    Please use plain text.
    Employee
    MartinBernat
    Re: Inventor 2013 Save .idw Copy As DWG problem with nuts
    11-21-2012 06:18 AM in reply to: axa-61
    thank you for posting the issue here.
    I tried chamfers and fillets on several parts but could not preproduce it. In your DWG I see the issue but seems to me that it has nothing to do with the chamfer. I suspect the edge (silhouette?).
    Could you please attach the source IDW as well?
    Martin Bernat
    11-22-2012 03:33 AM in reply to: MartinBernat
    For some strange reason this happens ONLY with nuts from content center . Not other parts/standard parts. Well I did not test all of them. And ONLY on one specific view projection as I shown it on the screen capture above. Top / side projections are fine, but not this one!
    Inventor 2013 SP1.1
    Windows 7, 64 bits
    RAM 8GB
    danny
    11-26-2012 02:11 PM in reply to: axa-61
    I have the same issue, also only at the nuts.
    Will try to attach a file later on.
    Regards
    Danny
    Inventor 2013 SP1.1 | Vault basic 2013 | HP Elitebook 8670W | win7 64b | 8Gb | GMT +1
