• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Mentor
    Re: Inventor 2013 SP1
    09-21-2012 01:21 PM in reply to: vmcarbonneau
    Have you installed SP1?
    John Retzlaff
    Please use plain text.
    09-21-2012 01:24 PM in reply to: john.retzlaff
    Just did it, inventor was stable, now it's super unstable
    09-21-2012 01:26 PM in reply to: vmcarbonneau
    Did you have any errors during the install?
    I had a machine have errors about not being able to close Windows Explorer, on this machine I uninstalled, re-booted, and then it was OK.
    John Retzlaff
    09-21-2012 01:34 PM in reply to: john.retzlaff
    No error displayed when installing SP1, I will try to do a clean reinstall of Inventor then SP1. Will see if it solves the problem
    blair
    09-21-2012 01:53 PM in reply to: john.retzlaff
    No problems with install or IV. Inventor actually seems faster.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    09-21-2012 01:54 PM in reply to: blair
    Yes, seems a little faster here too.
    John Retzlaff
    Employee
    09-21-2012 02:47 PM in reply to: sbixler
    Sam,
    A 1402 error indicates that you do not have permissions to write to a specific key in the registry. In the error it should tell you where it is trying to write to. You'll need to run regedit, find that key, Rt click go to permissions & ensure that Everyone has Full permission.
    If that does not fix it then Set “Everyone” full permission to : HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer
    Chris
    Chris Mitchell
    Inventor Quality Assurance Team
    09-24-2012 05:28 AM in reply to: john.retzlaff
    Install went fine on 64-bit, don't have any machines that run 32-bit anymore, so not sure there. Inventor seems a little faster, will know more after today.
    jdits7
    Autodesk Inventor Certified Professional
    Blog - http://inventortopix.blogspot.com
    Twitter - @InventorTopixJD
    *Pro
    09-24-2012 05:55 AM in reply to: chrismitchell01
    I no longer have a record of the specific path that was mentioned, but 2013 is the first version in which this has happened (all the way back to 5.3).  The administrator account that I am using to install the SP is the same one I used for installing 2013 RTM, and therefore the account which created that section of registry.  It works on some machines, or perhaps in some circumstances, not on others.  But I have uninstalled and reinstalled from an udated deployment with no issues on the machines that threw the error.
    Active Member
    09-25-2012 10:28 AM in reply to: sbixler
    It looks like that SP1 has been removed from the download area????
    I just downloaded and installed it this morning and now the page is missing.
