• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Inventor 2013 SP1.1 - error 1328 config.msi
    170 Views, 0 Replies
    01-22-2013 12:26 AM
    Hello
    I have some problem when i update inventor 2013 sp 1.1
    when I attempt to apply the patch I get the following error...
    "Error 1328. Error applying patch to file C:\Config.Msi\PT67C.tmp. It has probably been updated by other means, and can no longer be modified by this patch. For more information contact your patch vendor."
    I did delete the autodesk folder and then reinstalled Inventor 2013
    but still does not work.
    Has anyone found a fix for this issue????
    is this issue window's file problem???
    Thanks.
    Please use plain text.
