• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    CadlineSupport
    Inventor 2013 SP1.1 - Error 1328
    304 Views, 2 Replies
    10-23-2012 03:42 AM
    Hi
    I get the following error when installing SP1.1 (SP1 is not installed).
    Error 1328. Error applying patch to file C:\Config.Msi\PT8AE0.tmp cannot be modified - consult your vendor.
    Can anyone advise?
    Please use plain text.
    Employee
    YoyoYue
    Re: Inventor 2013 SP1.1 - Error 1328
    10-23-2012 07:23 PM in reply to: CadlineSupport
    Thanks for your report.
    Would you please provide more information about the error which you encountered?
    Such as which OS, and detailed steps. It will help us a lot to do further investigation.
    Thanks.
    Employee
    YoyoYue
    10-24-2012 02:13 AM in reply to: CadlineSupport
    Please reinstall Inventor in control panel and patch the SP1.1 build again.
    If it still does not work, would you please upload the log file under %temp% ?
    A latest txt file in that folder, and the format of the name is a few like "MSIf936d.txt"
    Thanks very much!
