• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Inventor 2013 - Lag Problem
    538 Views, 11 Replies
    07-03-2012 06:01 PM
    Hi guys,
    I have just installed Inventor 2013. I was running Inventor 2012 before and everything was fine.
    Now, I am noticing that when I click to edit a dimension for a new part that I have created, it takes a few seconds of delay before I type anything. This is so annoying especially when you do it all the time.
    I highly doubt it has anything with the spec of my desktop but anyway it is the following:
    Model : HP Z400 Workstation
    Processor: Intel(R) Xeon(R) CPU W3670 @ 3.2GHz
    RAM: 16GB
    Operating System: Windows 7 Professional Service Pack 1 (64bit)
    Graphics Card: Nvidia Quadro 4000
    Any help would be appreciated.
    (N.B: I use a Logitech M500 corded mouse if ever it makes any difference.)
    Please use plain text.
    Distinguished Contributor
    Re: Inventor 2013 - Lag Problem
    07-03-2012 07:48 PM in reply to: thegourou20
    Not just in dimension editing.
    Try switching off components visibility in assembly view in idw, or any general update, constraint application etc. the time-waiting donut just does not want to stop spinning. Very fustrating.
    I wish I've never installed 2013. I could do nicely without the (for me) completely useless fancy complicated new material and appearance system.
    Julian
    IV2013 Product design Suite Premium.
    Dell M6400
    12 GB RAM
    Windows 7 Ultimate 64 Bit
    Nvidia Quadro FX3700M 1 GB
    Active Member
    01-23-2013 10:17 AM in reply to: jrapert
    Similar specs here -
    IBM Thinkstation E30
    Xeon E31240 3.3Ghz
    8 GB Ram
    Quaddro 2000
    Latest service pack (1.1), Running Kaspersky antivirus
    Same issue.
    Anyone have ANY input?
    Distinguished Mentor
    01-23-2013 10:28 AM in reply to: thegourou20
    You might try adding an exception to your anti-virus so it excludes scans on the Autodesk folder and subfolders, to see if that makes any difference.
    John Retzlaff
    *Expert Elite*
    karthur1
    01-23-2013 10:41 AM in reply to: thegourou20
    Under Tools>Application options.... make sure it is set to either Performance or compatibility.  Software graphics is the slowest.
    Are you using custom materials/appearnces?  If you have not modified any you should be good to go with the default stuff that installs.
    Active Member
    01-23-2013 11:22 AM in reply to: john.retzlaff
    It is set to performance - I've tried everything with no solution.
    I have put in a request for exceptions in the Anti-virus, so far no response.
    I have noticed that every click in Inventor causes Kaspersky to scan several files.
    *Expert Elite*
    DarrenP
    01-23-2013 11:34 AM in reply to: Telson.Hadden
    try disabling kaspersky and see what happens
    Active Member
    01-23-2013 12:56 PM in reply to: DarrenP
    I would love to.  We're locked down tighter than fort knox, so I'm not allowed to disable kaspersky in any way, and I can't get any response from IT.
    01-23-2013 01:03 PM in reply to: Telson.Hadden
    Typical!
    John Retzlaff
    Active Contributor
    Leander.van.Gorsel
    01-24-2013 04:11 AM in reply to: thegourou20
    Have you installed the Inv. SP 1.1 + update?
    Do you use Vault?
    Green check.png  Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful
    Software: Inventor Series 2013 SP1.1 x64
    OS: Windows 7 Professional x64
    CPU: i7-975X // RAM: 12Gb
    VGA: GeForce GTX 280M
