• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    chrishutchinson6900
    Inventor 2013 Custom Materials Library Creation
    776 Views, 5 Replies
    04-24-2012 12:45 PM
    Is there a good source of material mechanical properties on the internet?  I have been creating a custom material library with the materials I normally use and I've just been duplicating a material from the supplied libraries to create mine with a name change only.  I'd like to include the correct mechanical properties if I could find a source of information that has all the properties in the format that the Inventor 2013 materials editor requires.
    Chris Hutchinson
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Inventor 2013 Custom Materials Library Creation
    04-24-2012 12:52 PM in reply to: chrishutchinson6900
    Hi chrishutchinson6900,
    Here is one source:
    http://www.matweb.com/
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    *Expert Elite*
    04-24-2012 01:30 PM in reply to: Curtis_Waguespack
    matweb is the best I've found.. I use it all the time.. Be prepared to do some annoying math to get the correct units for Inventor.
    I wish Inventor had more of a dropdown next to each value allowing you to enter any of the common unit formats and it would do the conversion for you..
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    RayFeiler
    04-25-2012 10:25 AM in reply to: mcgyvr
    I use convert.exe
    http://wscope.com/convert.htm
    Product Design Suite Ultimate 2014 64-Bit Update 1
    Sometimes you just need a good old reboot.
    *Expert Elite*
    mrattray
    04-25-2012 10:43 AM in reply to: RayFeiler
    I typicaly just use google. It's quite capable for most common math and conversions. I downloaded you converter though, it looks useful.
    Mike (not Matt) Rattray
    Active Contributor
    09-25-2012 03:13 AM in reply to: mcgyvr
    For that purpose, you can change units for whole material library, then edit it, and change units back. You can do that in material library bottom left options.
    Factory design suite 2013 premium
    Some old workstation ...
    Fancy HP LCD
    :smileyhappy:
