Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Inventor 2013 Crashes when trying to access applicatio n options
- Highlight
- Email to a Friend
Inventor 2013 was working just fine until I installed SP1.1 X64. Now it just locks up the second I try to access the application options.
Re: Inventor 2013 Crashes when trying to access applicatio n options
- Highlight
- Email to a Friend
Hello Rhjones,
From system, there is only one CER submited at 10/31/2012, which is afte Inventor 2013 Sp1.1 launched. This CER does not contact with any defect, it sounds a random one as you described.
Does Inventor crash in later time? Could you repeat the steps?
Yong Jing
Product Support Specialist
Frontline Technical Support, CSS. GCSO
- Highlight
- Email to a Friend
I'm getting the same problem. Inventor works just fine until I click on Applications Options. Then everything freezes. I am using a HP laptop.
Any suggestions on what's causing this.
- Highlight
- Email to a Friend
2013-02-15
SAME PROBLEM
This used to work, can not remember the last time.
BUT SYSTEM NOW FREEZES WHEN HITTING APPLICATION OPTIONS
NEED TO CLOSE PROGRAM USING SYS MAN TO REOPEN
XPS 1710 DELL LAPTOP - WIN 7 ULTI
HELP
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
STILL NOT WORKING
CONTROL PANEL
ADD REMOVE
INVENTOR 2013
REPAIR
FIXED
REBOOT
STILL NO GOOD
RUN **** AMINISTRATOR
STILL NO GOOD
- Highlight
- Email to a Friend
As LarrenSmoot said, normally this crash issue happens at the a specail use account, try to log in software as local computer's administrator to check issue still exist or not. If issue disappared, please check the special user account profile, otherwise, could you submit the CER to analysis this issue? We could not reproduce it at our site.
Yong Jing
- Highlight
- Email to a Friend
OK - IT WILL WORK IF I LOG IN AS ANOTHER ADMIN USER ???
WHATS UP??
WHAT DO I NEED TO RESET, CHANGE, LOOK AT ???
HELP
- Highlight
- Email to a Friend
Could you submit the CER to us?
Yong Jing
- Highlight
- Email to a Friend
OK - HOW DO I DO THAT ???
WHERE IS IT LOCATED ??
THANKS
