Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Inventor 2013 Crashes When Clicking Draw Operation in Sketch Mode
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sounds as if the whole user section of the registry (the one you deleted) didn't get re-created properly. Try deleting that registry key again, and while you're at it, check the permissions on the whole Autodesk key.
Nevermind, I figured it out. Inventor created a Reg folde...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Nevermind, I figured it out. Inventor created a Reg folder named RegistryVersion0.0. Deleting that and restarting Inventor a few times solved it. I got my color options back also.
P.s. Didn't see your post until i posted this response. Thanks for your help!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please help, not sure where or how to find:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\Regis
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't have time to give you a tutorial on the Windows registry (if I even knew enough to do so!), so you may want to do some research yourself. Suffice to say that every aspect of operating your computer and all its installed applications is directed by the registry. Editing it manually is sometimes useful, but one wrong move can hose an application, or the entire computer. The registry editor is "regedit.exe" (clever name, huh?).
The registry is a hierarchical structure, sort of like folders and files on your hard drive. Just be careful not to change anything that you're not sure of. But you can delete the key noted above (Version 17.0) and Inventor will re-create it the next time you run it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you, I managed to delete it no problem. First time coming across regedit.exe but it was user-friendly enough to work without any research and it has fixed the crashing problem so I'm very grateful!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How do you get to the registry?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Read my previous post above...
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
