Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Inventor 2012... missing prompt
- Highlight
- Email to a Friend
When I open an assembly yesterday in Inventor 2012, I get the "Changes have been made to some assembly components since ...blah, blah, blah". I checked the "Do not show this message again EVER" and clicked "Yes". Thought that would be the end of it.
Today, seen the same message. So I went to the application options and noticed that this prompt is not listed under the prompts tab (or at least I couldnt find it). It is there in 2011. Is there another way I can kill this prompt?
I am using Inventor 2012, SP1.
Re: Inventor 2012... Missing prompt
- Highlight
- Email to a Friend
If you do not have an option to suppress the warning at the time it's available, and there is no longer an option to select it in option then I'm hard pressed to think of a way to avoid it.
I wish I had a better idea but, you could use this link to request that it be added back:
http://usa.autodesk.com/adsk/servlet/index?siteID=
Dave Anderson
MFG Support - Inventor
Autodesk, Inc.
If I have answered your question, please "Accept Solution" so others may benefit as well.
- Highlight
- Email to a Friend
Dave,
Thats what I was trying to explain.... maybe I didnt do to good of a job. When the message came up, I did have options so I picked to "NEVER" show the prompt again.
When I seen that prompt again, I wanted to see how it was set in the app options. When I could not find it there, then I knew something was hosed.
Re: Inventor 2012... missing prompt
- Highlight
- Email to a Friend
Bump.
Not holding my breath at all but,
I get this message almost every assy I open, & guess what I have MADE CHANGES to some components, its part of the job I do :-)
I tick the Do Not Show show this message EVER AGAIN box, guess what, I see this message again.
Will the removal of this prompt be making a comeback in a service pack soon?
ADesk? Dave Anderson? you didn't understand the question/issue correctly, you replied but didn't follow the next reply.
Inventor 2012 Suite 64bit SP1
Gigabyte X58A-UD5 Motherboard
Intel i7 950 @ 3.06GHz
6GB DDR3 2000MHz
500GB Seagate SATA HDD
Inno3D Nvidia GeForce GTX 570 (Driver 8.17.12.8562 (15Oct11))
Win7 Pro 64bit
SpaceNavigator (10.0.11)
- Highlight
- Email to a Friend
If you had made a selection to the prompt initially, and now would like to change it, you could try deleting the HKEY_CURRENT_USER\Software\Autodesk\Inventor\Regis
I've logged this with development for investigation to determine if there is a way to add it back,.
Dave Anderson
Autodesk, Inc.
- Highlight
- Email to a Friend
Dave,
I deleted the key like you suggested. Then started 2012 and opened an assy. When the "Changes have been made to some assembly components..." came up, I checked the "Do not show this message again ever", then picked "Yes". The assembly opened. I closed it, then closed Inventor. I checked the registry under HKEY_CURRENT_USER\Software\Autodesk\Inventor\Regis
If I make changes in the Tools>Application options>Prompts, those changes are written to the \\\RegistryVersion16.0\System\Preferences\Prompts folder. For some reason, the prompt in question does not ever write anything to the registry. Guess that is why I have to do this everytime I close\reopen 2012.
Works fine in 2011, but not in 2012.
- Highlight
- Email to a Friend
Exactly the same problem here, Inventor 2012 SP1, Win7-64 bit.
