• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    karthur1
    Inventor 2012 file open dialog
    310 Views, 5 Replies
    08-30-2011 07:13 PM
    In Inventor, when I go to open a file, Inventor remembers the previous fileaname and path (thats good) but I still have to drag the vertical scroll bar to get to the file. If the number of files in the directory is small, then this is a non-issue (you dont have a vert scroll bar), but if it is a large directory, then it becomes a problem.
    Watch this video....http://screencast.com/t/YYmm5jeg
    In this video, I first open the -19 part, then next I open the -23 part.  I have to pull the scroll bar down to get to this part.
    It should remember the filename, path AND highlight the filename in the window.  Here is a thread about the same issue in 2011...http://forums.autodesk.com/t5/Autodesk-Inventor/File-Open-dialog/m-p/2705669/highlight/true#M378013
    Will we E-V-E-R get this to function correctly?
    This is in Inventor 2012, sp1.  Running on Win7x64.
    Please use plain text.
    Employee
    MartinBernat
    Re: Inventor 2012 file open dialog
    08-31-2011 03:24 AM in reply to: karthur1
    This seems to be a Win7 issue, I could not reproduce this in Inventor x32 nor x64 on WinXP.
    I've found similar issue in our database and I will ask Product Design to prioritize it.
    Thanks for reporting!
    Martin Bernat
    *Expert Elite*
    karthur1
    09-01-2011 11:35 AM in reply to: MartinBernat
    Martin,
    For what its worth,  When I do a Open>Open from Vault, the last filename that I opened from vault is highlighted in the window (the way that its supposed to work).
    Regards
    Distinguished Contributor
    12-22-2011 02:30 PM in reply to: karthur1
    Does anyone have a solution to this yet?  From my experience it is definately a Windows 7 issue, but I don't know how to fix it.
    rush02112
    12-18-2012 12:02 PM in reply to: shastu
    This was working for me up until a couple of weeks ago from a workstation reformat. I vaguely remember there being a registry fix for this issue but can not find what it was. Is this fixed for 2013?
    BLHDrafting
    12-18-2012 08:12 PM in reply to: karthur1
    Not a fix but handy. I often click on the Name column to do a reverse sort. It gets me to the bottom. Obviously doesn't help with anything in the middle of the list but resizing the wondow can help also.
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
