• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    carl_mgfx
    Inventor 2012 does not close
    325 Views, 4 Replies
    02-09-2012 02:53 AM
    Hi all
    I have experienced this on multiple computers and I am stumped as to why....
    I have install Product Design Suite (either Premium or Ultimate, 32bit or 64bit) on multiple computers.  I set it up to install with the available service packs (off an external HDD) and fill in the required option, serial, product key etc.  For some this work smoothly while on others Inventor 2012 will not shut down after I open it for the first time and then click the "close" cross at the top right.  I have waited for over 10min and nothing, eventually I will "end task" on Inventor to close it.
    Am I doing something wrong with these installs, is it the computers?  Has anyone else had this issue? And how was it resolved?
    Kind Regards
    Carl van Rooyen
    Kind Regards
    Carl van Rooyen
    Application Engineer
    EliteBook 8530w
    Win 7 Pro 64Bit SP1
    Core2 Duo T9400
    4 GB Ram
    Quadro FX 770M
    Distinguished Mentor
    MariaManuela
    Re: Inventor 2012 does not close
    02-09-2012 03:33 AM in reply to: carl_mgfx
    Hehe...the problem of the year.
    Read this:
    http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-hangs-trying-to-Exit/m-p/3263968#M420991
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    New Member
    opzmei
    02-09-2012 04:19 AM in reply to: carl_mgfx
    Hi
    I am having the same problem with Product Design Suite Ultimate 2012 x64.
    Installation is performed from the administrative deployment with integrated service packs for all products.
    Inventor 2012 will not shut down after I open it. The "end task" on Inventor to close it is the only solution.
    Kind Regards
    Andrew
    ***Guru
    TravisNave
    02-09-2012 09:19 AM in reply to: opzmei
    Have you tried disabling the communication center?
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    opzmei
    02-09-2012 09:55 AM in reply to: carl_mgfx
    Maria Manuela Pinho posted above  the correct link.
    The answer is that Inventor Optimization Update requires 15-20 minutes for downloads and does not allow to close the Inventor 2012 window.
    The problem is solved, thanks.
    Andrew.
