Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Inventor 2012 does not close
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all
I have experienced this on multiple computers and I am stumped as to why....
I have install Product Design Suite (either Premium or Ultimate, 32bit or 64bit) on multiple computers. I set it up to install with the available service packs (off an external HDD) and fill in the required option, serial, product key etc. For some this work smoothly while on others Inventor 2012 will not shut down after I open it for the first time and then click the "close" cross at the top right. I have waited for over 10min and nothing, eventually I will "end task" on Inventor to close it.
Am I doing something wrong with these installs, is it the computers? Has anyone else had this issue? And how was it resolved?
Kind Regards
Carl van Rooyen
Carl van Rooyen
Application Engineer
ProBook 4530s
Win 7 Pro 64Bit
i3 - 2310M
6 GB Ram
Intel HD Graphics
Re: Inventor 2012 does not close
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hehe...the problem of the year.
Read this:
http://forums.autodesk.com/t5/Autodesk-Inventor/In
Application Enginner
Cadtech.Asidek | Autodesk Gold Partner
http://cadtech-asidek.blogspot.com/
www.cadtech.pt | www.cadtech.es | www.asidek.es
Autodesk Inventor Professional 2013
Windows 7 Professional 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I am having the same problem with Product Design Suite Ultimate 2012 x64.
Installation is performed from the administrative deployment with integrated service packs for all products.
Inventor 2012 will not shut down after I open it. The "end task" on Inventor to close it is the only solution.
Kind Regards
Andrew
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you tried disabling the communication center?
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Inventor 2012 does not close
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Maria Manuela Pinho posted above the correct link.
The answer is that Inventor Optimization Update requires 15-20 minutes for downloads and does not allow to close the Inventor 2012 window.
The problem is solved, thanks.
Andrew.
